Expression Try Tag not Found Failover
I have an expression on an INT tag in a UDT that is using binEnc() to combine some bits like so
binEnc(
{[.]1},
{[.]2},
try({[.]3},0),
try({[.]4},0),
try({[.]5},0),
try({[.]6},0)
In this instance, only 1 and 2 exist. So, shouldn't 3, 4, 5, and 6 fail over to 0? My tag throws an error, saying the tag is not found. Shouldn't that error failover?
Can you show the relevant UDT structure?
This is the INT with the expression.
If I use
binEnc(
{[.]1},
{[.]2},
if(isNull({[.]3}),0,{[.]3}),
if(isNull({[.]4}),0,{[.]4}),
if(isNull({[.]5}),0,{[.]5}),
if(isNull({[.]6}),0,{[.]6})
instead I get the result I want. I thought the try would behave the same and catch the null.
I don't know, but wouldn't an INT have all 32 bits defined?
The rest would be 0 (implicit). Just combining these 6 into an INT (max 63) which can still be represented by a 32 bit
This is more readable
binEnc(
	{[.]1},
	{[.]2},
	coalesce({[.]3}),0),
	coalesce({[.]4}),0),
	coalesce({[.]5}),0),
	coalesce({[.]6}),0),
Ya, that's what I was trying to do with the try! Just using the wrong function.
Thanks!
