I want to be able to configure an alarm display path with the Tag name… Unfortunately it does not appear that I can use the following "AlarmPath+ + {Name}
How else can I bind to the tag name?
Did you try using the {fullItemPath} property. That should get you what you want, unless I’m misunderstanding what you’re trying to accomplish.
