I have a SQL query bringing a simple dataset into a custom property. I did it via dataset just because I wanted to use SQL to get the latest recorded value (order by XYX desc limit 1 kind of thing). From that single row dataset, I want to bind and show the values. The problem is that sometimes (often), the query returns NO rows. This is normal and expected. The issue is, I can’t get the expressions using the dataset (like x.y.z.data[“user”]) to stop faulting out on index out of range…
Any help appreciated.
Bit of an update- I found that if I query the two fields separately I can handle the issue with fallback value. So “crisis” over…but it would be good to know if there is a way around the original issue.
