Extended properties Allen Bradley
Dear,
Can the logix driver read the extended properties of a tag into a compactlogix/contrologix?
Regards
Arnaud
Only Factorytalk can read extended properties (.@description etc) from Logix controllers.
I think you might be able to move extended properties into its own tag on the PLC though, which then would be available via OPC
I don’t think so. Let us know though. :slight_smile:
Hi Everyone,
Thanks for your reply.
Here is an update.
Like @neil2 say (By the way, welcome on the forum), the logix driver of ignition doesn't support the read of extended tag properties.
@kelly.draehn, i've just tried and you cannot put a tag extended properties into another tag value.
To solve my problem there is two solution:
  • Use the extended properties on the ignition tag
  • Use memory tag in ignition to store my information.
    I've choose for the second one.
Regards
Arnaud
