I must be close, sorry if this is a simple one; I want to extract the value of a specific column of a row of a table on a Perspective view when it is double - clicked, so I can pass that value as a param to a view that will pop up and display further detail. What is the syntax for line #2 of the attached for extracting that table data (since what is there isn’t doing it)? Thanks much!
Assuming that the props.data is a dataset type the syntax would look like:
RunID = self.data.getValueAt(event.row, "RunID")
Hi @jeff.ryan,
Why are you not using the event.value this give you a json string. Then you can extract the value you need.
@Arnaud_Declerck , lack of familiarity and experience… But now I know.
I got there. Thanks to both of you. As I think somehow the GetValueAt would do it. But this is what I need. Thanks.
Little correction it's a dict not a string ![]()
Experience comes with time and practice trust me ![]()
I few month ago i was asking such questions also.
All the best with your project
Regards
