I am using the 8.0.14 nightly, and seem to be having some troubles with a simple OPC Browse
I am trying to look through the folder that I have highlighted, and my script takes absolutely ages to run and then just times out.
Is there some simple thing that I am missing here?
EDIT: Also tested this on 8.0.12 with another gateway, same issue
Even if I add the SLC simulator and run the same example listed in the docs, it does the same thing and eventually times out.
https://docs.inductiveautomation.com/display/DOC80/system.opc.browseSimple
You also cant interrupt it or it will just continue until it times out anyway.
We use browseServer for something like this.
Steve wrote and documented a nice piece of code for it in the above thread.
Something does seem wrong with this function right now. It’s doing a recursive browse at too early a starting point or something.
As suggested, use browseServer, which is always preferred to browse or browseSimple which should really be marked deprecated.
That worked! Thank you guys so much
