Facial recognition for login
Hi all,
Is there a way to login a user via scripting?
I have a setup where I can scan a users face, verify they exist in database and get their user id, all I need to do is login them automatically once this is done.
Thanks in advance.
After verifying whether the user is in the database, you could - instead of using their userID - login with the following function: system.perspective.login | Ignition User Manual
This would, however, start a session without authentication, so you wouldn’t directly be able to see which user is logged in.
No, you cannot. That function doesn't allow injecting a desired userID, because Identity Providers don't allow it. (And it would be a huge security hole.)
Not in Perspective.
You would need to use an external Identity Provider that securely did that itself. (You could write one--SAML is an open standard.)
My wording may not have made it clear, but I did not mean the user would be logged in. I was suggesting the facial recognition outside of ignition already verifies the user, so OP could make a choice to not use any extra level of verification and just open an unauthorized session after facial recognition is complete.
A user already has that just by opening Perspective, which they would have to have done to be able to use system.perspective.*. :man_shrugging:
You are essentially saying to just store the result (in a session var, perhaps) and just hand-roll all further security. Not terrible, but cuts off a lot of security options.
The user in my situation needs to be verified , ie logged in with a session on the Ignition gateway.
How hard is it to write and setup a one-SAML?
I've never done it. But it is an open standard with open documentation.
