Facing Issue with report Viewer
Hello guys,
I'm facing issues when I'm trying to pass the params of StartDate and EndDate in the view.My report goes blank.Why is this happening?What can I do to resolve this and pass params from view/report viewer params at the same time
Your error is with the source property, which means the report name that you have provided is not valid. Do you have a report called TagHistory? Make sure you include the full path to the report if it is in a folder.
Also, your start and end date parameter values are strings. Does your report expect these parameters to be string type or date type?
