I just rebooted my virtual machine running the FactoryPMI software. From within that virtual machine, I cannot connect to gateway with the designer. However, the Gateway status monitor is working, along with the web interface.
java.net.ConnectException: Connection refused: connect
The gateway is running on the same machine, and on the default port of 8005. Is this a known issue? Thanks in advance.
Side note: I also noticed that when things are working properly, changing the gateway’s port to anything besides 8005 causes the designer to have problems connecting. It seems that it always tries to connect to the gateway at localhost:8005, and this can be somewhat irritating when running the gateway on a different port. Is there a way to point the designer to a different port?
