FactoryTalk Transaction Manager AOI replacement?
This might be asking a bit much, but does anyone have an Allen Bradley AOI that they use in place of a FactoryTalk TM AOI? Or just a very reliable Allen Bradley / Ignition Transaction Groups AOI? We recently migrated a customer away from a bunch of FactoryTalk stuff to Ignition, and one of the things I replaced was transaction manager. I wrote my own AOI to do that, which works about 99% of the time… Other times I get duplicate entries and need to go and manually remove them from the database. If anyone has anything in terms of a reliable Allen Bradley AOI for handling hourly database records that would be really helpful.
Unfortunately one of the hurdles is that the recorded time comes from the PLC, and once a year for Daylight savings time, there will be a duplicate entry ( I hate DST SO much…), so unfortunately ticking the box for “only evaluate when values have changed” isn’t an option.
Consider using the 64-bit wallclock current value (unix epoch microseconds) as your trigger. That’s in UTC and will yield the correct time regardless of DST. Divide by 1000 to pass to system.date.fromMillis().
hrm, in this scenario the timestamp really needs to come from the PLC so there’s not really a way around it
I’m talking about the internal clock of the PLC.
