Hi everyone,
Anyone who has migrated a FactoryTalk View project to Ignition knows most of the time goes into redrawing displays, rebuilding tags and alarms, and chasing VBA. We built a module to do that work: ZIMAM Migrate, now in beta.
What it does
It reads a FactoryTalk View SE or ME export (displays, tags, alarms, parameters and VBA scripts) and builds an Ignition 8.3 Perspective project from it.
Three ways to migrate
- Convert Classic: keeps every display exactly as drawn
- Convert Modern: the same displays with a clean, modern look
- Rebuild Modern: a new operator-first project, with an overview, pages, cards and faceplates, following ISA-101
Nothing is guessed
- Anything that can't be proven goes into a migration report with the reason
- Every reading keeps its own name and unit
- A command only appears where the original project already writes that tag
- Missing tags and scripts get a proposed fix, and only the fixes you tick are applied
- A script only runs after the engineer approves the exact code
Review before anything goes live
- A wizard: Project, Tags, Look, Missing tags & scripts, Create
- ZIMAM Studio: a live draft of the new project you can change on the canvas or through chat (English or Arabic). Reads stay live, writes are captured and never sent to the plant.
- Undo, What-if and Publish, and Publish takes a backup first
- An ISA-101 design review with one-click fixes
- ISA-5.1 tag names are parsed into equipment, instruments and loops, and faceplates are generated from the drawn equipment
Details and demo booking:
Questions and criticism are welcome.
If you'd like to follow our work, a follow on LinkedIn would mean a lot:
