Failed rectangles
I get the error below when I try to launch a mobile project. The project works if I launch it as a regular project.
Ignition 7.5.3
Java 1.7.0_09
INFO | jvm 3 | 2012/11/13 15:58:57 | INFO [ClientVM ] [15:58:57,922]: Client vm 3f3e14ee-1452-e646-87c4-da5f2b8078df closed: IOException during rectangle message: java.io.EOFException INFO | jvm 3 | 2012/11/13 15:58:57 | WARN [RectsB64 ] [15:58:57,922]: Failure in mobiledata/rects INFO | jvm 3 | 2012/11/13 15:58:57 | java.io.EOFException INFO | jvm 3 | 2012/11/13 15:58:57 | at java.io.DataInputStream.readShort(Unknown Source) INFO | jvm 3 | 2012/11/13 15:58:57 | at com.inductiveautomation.mobile.gateway.MobileVMManager$ClientVMImpl.getDirtyRectangles(MobileVMManager.java:447) INFO | jvm 3 | 2012/11/13 15:58:57 | at com.inductiveautomation.mobile.gateway.servlets.MobileSession.getDirtyRectangles(MobileSession.java:224) INFO | jvm 3 | 2012/11/13 15:58:57 | at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet$RectsBase64.handle(MobileDataServlet.java:253) INFO | jvm 3 | 2012/11/13 15:58:57 | at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet.doRequest(MobileDataServlet.java:144) INFO | jvm 3 | 2012/11/13 15:58:57 | at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet.doGet(MobileDataServlet.java:94) INFO | jvm 3 | 2012/11/13 15:58:57 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) INFO | jvm 3 | 2012/11/13 15:58:57 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) INFO | jvm 3 | 2012/11/13 15:58:57 | at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583) INFO | jvm 3 | 2012/11/13 15:58:57 | at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447) INFO | jvm 3 | 2012/11/13 15:58:57 | at java.lang.Thread.run(Unknown Source)
Do you have Java 7? Our mobile module is only compatible with Java 6. Furthermore, you have to specify the right path to Java 6 in the mobile settings in the gateway configuration page. Make sure that your path is correct.
Java 7 would be the problem.
Given that you can specify the path, can the gateway run on 7 with the mobile module running on 6?
When will it support 7?
That's worth a shot...
Never :frowning:
Whatever Mobile.Next is will run on Java 7, but the current incarnation won't ever be compatible.
Yes it can! :smiley:
