Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
Installed first time ignition on my system (windows 10) and getting below error =
See below wrapperm.log
STATUS | wrapperm | 2020/10/21 22:16:08 | Ignition service installed.
STATUS | wrapperm | 2020/10/21 22:16:08 | Starting the Ignition service…
STATUS | wrapper | 2020/10/21 22:16:08 | --> Wrapper Started as Service
STATUS | wrapper | 2020/10/21 22:16:08 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper | 2020/10/21 22:16:08 | Copyright © 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2020/10/21 22:16:08 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2020/10/21 22:16:08 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2020/10/21 22:16:09 | Launching a JVM…
INFO | jvm 1 | 2020/10/21 22:16:10 | WrapperManager: Initializing…
INFO | wrapperm | 2020/10/21 22:16:13 | Waiting to start…
INFO | wrapperm | 2020/10/21 22:16:18 | Waiting to start…
INFO | wrapperm | 2020/10/21 22:16:23 | Waiting to start…
INFO | wrapperm | 2020/10/21 22:16:28 | Waiting to start…
INFO | jvm 1 | 2020/10/21 22:16:31 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
INFO | jvm 1 | 2020/10/21 22:16:31 | WrapperManager Error: Exiting JVM…
ERROR | wrapper | 2020/10/21 22:16:32 | JVM exited while loading the application.
INFO | wrapperm | 2020/10/21 22:16:33 | Waiting to start…
STATUS | wrapper | 2020/10/21 22:16:37 | Reloading Wrapper configuration…
STATUS | wrapper | 2020/10/21 22:16:38 | Launching a JVM…
INFO | wrapperm | 2020/10/21 22:16:38 | Waiting to start…
INFO | jvm 2 | 2020/10/21 22:16:38 | WrapperManager: Initializing…
INFO | wrapperm | 2020/10/21 22:16:43 | Waiting to start…
INFO | wrapperm | 2020/10/21 22:16:48 | Waiting to start…
INFO | wrapperm | 2020/10/21 22:16:53 | Waiting to start…
INFO | wrapperm | 2020/10/21 22:16:58 | Waiting to start…
INFO | jvm 2 | 2020/10/21 22:16:59 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
INFO | jvm 2 | 2020/10/21 22:16:59 | WrapperManager Error: Exiting JVM…
I have never seen this before, but if I had to guess I’d say you already have some other software running on port 32000. Can you check if that’s the case? Run something like netstat -a from a command prompt and see if anything is using that port.
Hi Kevin,
Issue resolved after open ports 3100 and 3200 in the firewall. Anyway thanks for the quick response.
Hi Neha, why did you open ports 3200 and 3100 when error was for 32,000? I am facing same error as you have originally posted.
Hi Kevin, have you seen this issue since this post? I am currently getting this error when trying to start the Ignition Gateway service.
I had to open inbound TCP port 32000 to get my Ignition service running again
