Dears
I have “gateway start up” script  which listing to port 31001 , it works well.
when i active telent script in port 23 , the startup scrip get the below error.
java.base/java.lang.reflect.Constructor.newInstance(Unknown Source) at org.python.core.PyReflectedConstructor.constructProxy(PyReflectedConstructor.java:211) java.lang.IllegalStateException: java.lang.IllegalStateException: failed to create a child event loop
Could you please help me about this issue.
Best Regards
              Are you listening to a port directly in your event script?  That ties up a thread of the gateway’s event handling thread pool.  Anyways, show your code.
              Kindly find script below
import socket
host = ‘192.168.1.1’
port=31001
while True:
try:
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind((host, port))
s.listen(5)
conn , addr =s.accept()
system.tag.write("[default]addr",addr)
while True:
data = conn.recv(512)
if not data :
s.close()
break
else:
system.tag.write("[default]data",data)
conn.sendall(“ok”.encode())
s.close()
except:
print (“TCP Listining Stopped”)
              Please edit your post to include code markers.  Use three backquotes above and below your code, so it looks like this in the editor:
pasted code
That said, you can’t loop forever in any event script.  You must use system.util.invokeAsynchronous() to launch a separate thread.
              Thanks for your help, i created script in project library with while loop to listen to specific port , and called it with system.util.invokeAsynchronous() in start up script , it worked well for a day then hanged , if i restart gateway ,it works again.
could you please help me about he best choice of running the script witch listen forever to  specific port>
Best Regards
