I'm trying to restore an IgnitionEdge gwbk I run into two scenarios:
Connections enabled - gateway does not restart and eventually times out and cannot access again
Connections disabled - when I try to enable the Tag Provider, I get the the following error and then the gateway is not accessible anymore after this message appears.
I'm restoring an 8.1.19 Ignition Edge gwbk .
Thoughts?
