Hello,
I’m working on a new module, and I copy/pasted a bit of code I had to set up a settings page and internal DB record. I’m testing this on a Docker Image for 7.9.16.
I keep getting the following exception:
Caused by: org.sqlite.SQLiteException: [SQLITE_SCHEMA] The database schema changed (near "Settings": syntax error)
My code to add the schema in the gateway hook is very simple:
private void verifySchema() {
try {
gatewayContext.getSchemaUpdater().updatePersistentRecords(CharmSettingsRecord.META);
} catch (SQLException e) {
logger.error("Error verifying internal database records for TamakiMES", e);
and my record is defined as:
public class CharmSettingsRecord extends PersistentRecord {
public static final RecordMeta<CharmSettingsRecord> META = new RecordMeta<>(CharmSettingsRecord.class, "Charm Server Settings")
.setNounKey("CharmSettingsRecord.Noun").setNounPluralKey("CharmSettingsRecord.Noun.Plural");
@Override
public RecordMeta<?> getMeta() {
return META;
public static final IdentityField id = new IdentityField(META);
public Long getId() {
return getLong(id);
public void setId(Long _id) {
setLong(id, _id);
Is there a way to debug this better?
Thanks Kevin
