We are using Ignition 8.1 as the SCADA to communicate with a TwinCAT runtime and SQL DB.
The feature I am trying to build:
An Ignition screen that allows users to select a number of variables to begin recording at a 10ms rate. I plan on buffering all signals into a 2D array in the PLC that will have a cumulative record of 1 sec worth of data.
I can constrain the signals the user can choose to record by the Ignition interface, but I will not know the exact variables/data types to be recorded until it is sent to the PLC. From what I know, this variability will cause issues with properly accessing data in the PLC and writing to the SQL DB from the PLC with built-in TwinCAT libraries (unless I use some middleware using a TwinCAT .DLL).
As I understand the SQL Bridge, I would need a transaction group or tag group at a 10ms rate to directly access the variables I want to record if I don’t do buffering. This seems like too fast a rate to do efficiently (but I’m not an SQL expert, or really an expert at anything).
Does anyone have feedback on how to accomplish this feature or a better way to go about this? I appreciate any feedback.
Thank you.
V/R,
Adam Haney
