Hi everyone,
I'm trying to use a POST method:
h = {"accept": "application/json", "Content-Type": "application/json"}
client = system.net.httpClient()
response = client.post(url, data=data, headers=h)
response.json
data is a dictionary.
I get this error:
{'detail': [{'msg': 'Field required', 'loc': ['body'], 'type': 'missing', 'input': None}]}
For context, I’m using FastAPI for my API.
The endpoint is defined like this:
@app.post("/item")
def update_item(new_item: Item):
And the Item model looks like this:
class Item(BaseModel):
t_stamp: str
temp_1: float
hum_1: float
temp_2: float
hum_2: float
temp_3: float
hum_3: float
temp_4: float
hum_4: float
temp_5: float
hum_5: float
temp_6: float
hum_6: float
The perplexing part is that if I use httpPost instead, it works fine:
import json
# Convert dictionary to JSON string
json_string = json.dumps(data)
# Use httpPost directly
response = system.net.httpPost(url, contentType="application/json", postData=json_string)
Thanks in advance for any help or advice
what happens if you try passing in json.dumps(data) to httpClient?
Can you share the actual dictionary you're sending?
What if you send your data to a testing tool like that echoes what you requested back to you?
I like http://httpbin.org/, though it appears to be down at the moment. It's self hostable via Docker: https://hub.docker.com/r/kennethreitz/httpbin/
Having same issue with put -
response = client.put(url, params = {'record_id':1} data={"ValueToUpdate":1.00}, headers=h)
response.json
pturmel
5
Why would you expect PUT to have a response body at all?
to see if the put was successful or was there any error.
This code snippet doesn't have a comma between your two parameters.
yes,
here is my function :
def clientPut( path = '', id = None, payload = {}):
if id is None:
return
headers = {
"Content-Type": "application/json",
value = client.put(path, params = {'record_id':id}, data = payload, headers=headers)
print value.request.headers
print value.json
return value.json
Here is the call:
clientPut(path = URL, id=411, payload = {"maximum":1.57})
this is what it prints when I use script console in designer:
{u'accept': [application/json], u'Content-Type': [application/json], u'User-Agent': [Ignition]}
{'detail': [{'msg': u'Field required', 'loc': [u'body'], 'type': u'missing', 'input': None}]}
Seems like a server problem to me; it works fine against an echo server:
from pprint import pprint
URL = "https://httpbingo.org/put"
if id is None:
return
headers = {
value = client.put(URL, params = {'record_id':id}, data = payload, headers=headers)
return value.json
pprint(clientPut(path = URL, id=411, payload = {"maximum":1.57}))
{'args': {'record_id': [u'411']},
'data': u'{"maximum":1.57}',
'files': {},
'form': {},
'headers': {'Accept': [u'application/json'],
'Content-Length': [u'16'],
'Content-Type': [u'application/json'],
'Host': [u'httpbingo.org'],
'User-Agent': [u'Ignition'],
'Via': [u'2 fly.io'],
'X-Forwarded-For': [u'207.173.137.144, 66.241.125.232'],
'X-Forwarded-Port': [u'443'],
'X-Forwarded-Proto': [u'https'],
'X-Forwarded-Ssl': [u'on'],
'X-Request-Start': [u't=1763134710144631']},
'json': {'maximum': 1.57},
'method': u'PUT',
'origin': u'207.173.137.144',
'url': u'https://httpbingo.org/put?record_id=411'}
I messaged the full trace.
Try this, because some servers are bad at negotiating HTTP_2 downgrades.
Make this call:
Into:
client = system.net.httpClient(version="HTTP_1_1")
