It typically takes about 15 seconds to failover to the backup server. For a realtime application, failover in one or two seconds is desirable.
What are you current settings for ping rate and failover time? Also, are you using cold or warm mode for the backup? 15 seconds seems a tad long, though I definitely think it’s a valid feature request to work on making the system faster to failover with fewer false triggers.
Regards,
