Faulted database connection?
Hi all,
I am attempting to setup a database connection in Ignition for the first time. I am using SQL Express 2022. I have tried lots of different settings in the gateway, but I keep getting "faulted" as my status.
I installed SQL Express 2022 and created a database called "database1." Do I need to do anything else in SSMS for the database to be functional. I have installed the MySQL Connector/J driver. I setup the database in the gateway follows:
Config>Databases>Database Connections>Create new Database connection>MySQL
Connect URL= jdbc:mysql://localhost:3306/SQLEXPRESS1
Should this be equal to "Server Name"? I have tried both. "SQLEXPRESS1" and "DESKTOP-S2UTNSE\SQLEXPRESS1," but both result in faults.
Username/Password have been verified to work in SSMS per SQL Server Authentication.
Extra Connection Properties: databasename=database1
Database1 is the name of my database in MySQL
That is the driver for MY SQL. Not MS SQL
Choose MSSql as the driver.
I had tried both, still faulted with MSSQL, unfortunately.
You are using SQL Express. That doesn't allow user/password authentication by default. (You will regret using it when you hit its size limits, too.)
jdbc:sqlserver://localhost\SQLEXPRESS1 should work fine if your database is running on the same machine, and if you left the port as the default 1433.
I've had no problems with user/password authentication with SQL Express. I would however agree with Phil and say that you should only use Express for testing on a dev environment (because of its size limits). In production, use SQL Server if you must use MS SQL.
The status page for database connections provides a more detailed message when the connection is faulted. What is the error message when you click on "Error" or the Details button on the Status page?
The docs have a lot of useful information, don't forget they exist.
