how can I resolve this problem about faulted gateway. it’s a re-installed ignition but the gateway says faulted
STATUS | wrapper | 2019/02/27 14:00:26 | --> Wrapper Started as Service
STATUS | wrapper | 2019/02/27 14:00:26 | Java Service Wrapper Standard Edition 64-bit 3.5.35
STATUS | wrapper | 2019/02/27 14:00:26 | Copyright (C) 1999-2018 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2019/02/27 14:00:26 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2019/02/27 14:00:26 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2019/02/27 14:00:26 | Launching a JVM...
INFO | jvm 1 | 2019/02/27 14:00:27 | WrapperManager: Initializing...
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,138 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\\logback.xml] at [file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/logback.xml]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,185 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,185 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,185 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,201 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,201 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,451 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@7c46d220 - Driver name=SQLite JDBC
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,451 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@7c46d220 - Driver version=3.20.1
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,451 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@7c46d220 - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2019/02/27 14:00:27 | 14:00:27,482 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@149321bc - Registering current configuration as safe fallback point
INFO | jvm 1 | 2019/02/27 14:00:27 | I [o.e.j.u.log ] [06:00:27]: Logging initialized @640ms
INFO | jvm 1 | 2019/02/27 14:00:27 | I [Jetpad ] [06:00:27]: Existing keystore found at C:\Program Files\Inductive Automation\Ignition\webserver\ssl.key
INFO | jvm 1 | 2019/02/27 14:00:27 | I [o.e.j.s.Server ] [06:00:27]: jetty-9.3.z-SNAPSHOT
INFO | jvm 1 | 2019/02/27 14:00:27 | I [o.e.j.w.StandardDescriptorProcessor] [06:00:27]: NO JSP Support for /main, did not find org.apache.jasper.servlet.JspServlet
INFO | jvm 1 | 2019/02/27 14:00:27 | I [c.i.i.g.b.SRClassLoader ] [06:00:27]: SRClassLoader init
INFO | jvm 1 | 2019/02/27 14:00:30 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2019/02/27 14:00:32 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2019/02/27 14:00:34 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.Application ] [06:00:34]: [WicketFilter] init: Wicket core library initializer
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.RequestListenerInterface] [06:00:34]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.RequestListenerInterface] [06:00:34]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.RequestListenerInterface] [06:00:34]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.RequestListenerInterface] [06:00:34]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.RequestListenerInterface] [06:00:34]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.RequestListenerInterface] [06:00:34]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2019/02/27 14:00:34 | I [o.a.w.Application ] [06:00:34]: [WicketFilter] init: Wicket extensions initializer
INFO | jvm 1 | 2019/02/27 14:00:34 | I [SRContext ] [06:00:34]: Ignition["/main", state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2019/02/27 14:00:34 | I [SRContext ] [06:00:34]: Starting Ignition 7.9.10 (b2018112821)
INFO | jvm 1 | 2019/02/27 14:00:34 | I [SRContext ] [06:00:34]: Reloading JDBC classloader.
INFO | jvm 1 | 2019/02/27 14:00:36 | W [SRContext ] [06:00:35]: Unable to read "catapult.metroKeystoreAlias" gateway.xml property. Assuming metro keystore alias is: metro-key
INFO | jvm 1 | 2019/02/27 14:00:36 | I [C.SecureRandomProvider ] [06:00:36]: Creating SecureRandom object...
INFO | jvm 1 | 2019/02/27 14:00:36 | I [C.SecureRandomProvider ] [06:00:36]: ... SecureRandom Created.
INFO | jvm 1 | 2019/02/27 14:00:36 | I [C.SecureRandomProvider ] [06:00:36]: Secure random seed generated in 0ms
INFO | jvm 1 | 2019/02/27 14:00:36 | I [o.a.w.p.h.WebApplication ] [06:00:36]: [WicketFilter] Started Wicket version 6.1.1 in DEPLOYMENT mode
INFO | jvm 1 | 2019/02/27 14:00:36 | I [o.e.j.s.h.ContextHandler ] [06:00:36]: Started o.e.j.w.WebAppContext@58c836d8{/main,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,AVAILABLE}
INFO | jvm 1 | 2019/02/27 14:00:36 | I [R.StateMonitoring ] [06:00:36]: Redundancy state changed: Role=Independent, Activity level=Active, Project state=Good, History level=Full
INFO | jvm 1 | 2019/02/27 14:00:36 | I [o.e.j.s.ServerConnector ] [06:00:36]: Started ServerConnector@16e0da7a{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO | jvm 1 | 2019/02/27 14:00:36 | I [g.InternalDatabaseManager ] [06:00:36]: Starting up...
INFO | jvm 1 | 2019/02/27 14:00:36 | I [P.InternalDatabase ] [06:00:36]: Looking for existing internal database "config.idb"...
INFO | jvm 1 | 2019/02/27 14:00:36 | I [P.InternalDatabase ] [06:00:36]: ... found existing.
INFO | jvm 1 | 2019/02/27 14:00:36 | I [P.InternalDatabase ] [06:00:36]: internal database "config.idb" started up successfully.
INFO | jvm 1 | 2019/02/27 14:00:36 | I [P.InternalDatabase ] [06:00:36]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database "config.idb"]
INFO | jvm 1 | 2019/02/27 14:00:36 | I [g.ModuleManager ] [06:00:36]: Loading modules....
INFO | jvm 1 | 2019/02/27 14:00:36 | I [o.e.j.s.ServerConnector ] [06:00:36]: Started ServerConnector@4c69d42a{SSL,[ssl, http/1.1]}{0.0.0.0:8043}
INFO | jvm 1 | 2019/02/27 14:00:36 | I [o.e.j.s.ServerConnector ] [06:00:36]: Started ServerConnector@78eae77a{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 1 | 2019/02/27 14:00:36 | I [o.e.j.s.Server ] [06:00:36]: Started @9807ms
INFO | jvm 1 | 2019/02/27 14:00:38 | E [SRContext ] [06:00:38]: Error during context startup.
INFO | jvm 1 | 2019/02/27 14:00:38 | java.lang.NumberFormatException: For input string: "??????????"
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.lang.NumberFormatException.forInputString(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.lang.Long.parseLong(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.processJarFiles(ModuleManagerImpl.java:2012)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.initClassloader(ModuleManagerImpl.java:1987)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.load(ModuleManagerImpl.java:1909)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.loadModules(ModuleManagerImpl.java:1115)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.init(ModuleManagerImpl.java:351)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:1218)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:224)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:1036)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.SRContext.access$300(SRContext.java:289)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:767)
INFO | jvm 1 | 2019/02/27 14:00:38 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2019/02/27 14:00:38 | I [SRContext ] [06:00:38]: Ignition["/main", state=STARTING] ContextState = FAULTED
Many thanks!
