After applying the new nightly the gateway keeps faulting.
— Wrapper.log —
STATUS | wrapper | 2019/01/08 06:53:39 | --> Wrapper Started as Daemon
STATUS | wrapper | 2019/01/08 06:53:39 | Java Service Wrapper Standard Edition 64-bit 3.5.35
STATUS | wrapper | 2019/01/08 06:53:39 | Copyright (C) 1999-2018 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2019/01/08 06:53:39 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2019/01/08 06:53:39 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2019/01/08 06:53:39 | Launching a JVM...
INFO | jvm 1 | 2019/01/08 06:53:39 | WrapperManager: Initializing...
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,138 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [/var/lib/ignition/data//logback.xml] at [file:/var/lib/ignition/data/logback.xml]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,253 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,254 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,258 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,289 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,295 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,426 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@6ba90240 - Driver name=SQLiteJDBC
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,426 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@6ba90240 - Driver version=native
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,426 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@6ba90240 - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,450 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,452 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,452 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,452 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,452 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,453 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,453 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,453 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,454 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,454 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,454 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,454 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,454 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,454 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2019/01/08 06:53:40 | 06:53:40,455 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@5f1c2f6 - Registering current configuration as safe fallback point
INFO | jvm 1 | 2019/01/08 06:53:40 | Scheduling logfile maintenance. Last maintenance: Wed Dec 31 19:00:00 EST 1969, events since then: 0
INFO | jvm 1 | 2019/01/08 06:53:40 | Starting logfile maintenance. Max entries: 50000
INFO | jvm 1 | 2019/01/08 06:53:40 | W [WebResourceManagerImpl ] [11:53:40]: Unable to read "gateway.metroKeystoreAlias" gateway.xml property. Assuming metro keystore alias is: metro-key
INFO | jvm 1 | 2019/01/08 06:53:40 | Cleaned up 129 rows in 403 ms. Vacuum performed: false
INFO | jvm 1 | 2019/01/08 06:53:40 | I [o.e.j.u.log ] [11:53:40]: Logging initialized @1539ms to org.eclipse.jetty.util.log.Slf4jLog
INFO | jvm 1 | 2019/01/08 06:53:41 | I [IgnitionServer ] [11:53:41]: Existing keystore found at webserver/ssl.key
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.e.j.s.Server ] [11:53:41]: jetty-9.4.8.v20180619, build timestamp: 2018-06-20T19:55:30-04:00, git hash: c9493e74cb4f10f4abbc9018a634e005155d6d6e
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.e.j.w.StandardDescriptorProcessor] [11:53:41]: NO JSP Support for /, did not find org.apache.jasper.servlet.JspServlet
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.e.j.s.session ] [11:53:41]: DefaultSessionIdManager workerName=node0
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.e.j.s.session ] [11:53:41]: No SessionScavenger set, using defaults
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.e.j.s.session ] [11:53:41]: Scavenging every 660000ms
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.Application ] [11:53:41]: [WicketFilter] init: Wicket core library initializer
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.RequestListenerInterface] [11:53:41]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.RequestListenerInterface] [11:53:41]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.RequestListenerInterface] [11:53:41]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.RequestListenerInterface] [11:53:41]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.RequestListenerInterface] [11:53:41]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.RequestListenerInterface] [11:53:41]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.Application ] [11:53:41]: [WicketFilter] init: Wicket extensions initializer
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.a.w.p.h.WebApplication ] [11:53:41]: [WicketFilter] Started Wicket version 6.1.1 in DEPLOYMENT mode
INFO | jvm 1 | 2019/01/08 06:53:41 | I [IgnitionGateway ] [11:53:41]: Ignition[state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2019/01/08 06:53:41 | I [IgnitionGateway ] [11:53:41]: Starting Ignition 8.0.0-beta0 (b2019010802)
INFO | jvm 1 | 2019/01/08 06:53:41 | I [IgnitionGateway ] [11:53:41]: Reloading JDBC classloader.
INFO | jvm 1 | 2019/01/08 06:53:41 | I [o.e.j.s.h.ContextHandler ] [11:53:41]: Started o.e.j.w.WebAppContext@6fe7c13e{/,file:///usr/local/bin/ignition/webserver/webapps/main/,AVAILABLE}
INFO | jvm 1 | 2019/01/08 06:53:42 | I [R.StateMonitoring ] [11:53:42]: Redundancy state changed: Role=Independent, Activity level=Active, Project state=Good, History level=Full
INFO | jvm 1 | 2019/01/08 06:53:42 | I [g.InternalDatabaseManager ] [11:53:42]: Starting up...
INFO | jvm 1 | 2019/01/08 06:53:42 | I [P.InternalDatabase ] [11:53:42]: Looking for existing internal database "config.idb"...
INFO | jvm 1 | 2019/01/08 06:53:42 | I [P.InternalDatabase ] [11:53:42]: ... found existing.
INFO | jvm 1 | 2019/01/08 06:53:42 | I [P.InternalDatabase ] [11:53:42]: internal database "config.idb" started up successfully.
INFO | jvm 1 | 2019/01/08 06:53:42 | I [P.InternalDatabase ] [11:53:42]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database "config.idb"]
INFO | jvm 1 | 2019/01/08 06:53:42 | WARNING: An illegal reflective access operation has occurred
INFO | jvm 1 | 2019/01/08 06:53:42 | WARNING: Illegal reflective access by com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl (file:/usr/local/bin/ignition/lib/core/gateway/gateway-8.0.0-beta.jar) to field java.lang.ClassLoader.usr_paths
INFO | jvm 1 | 2019/01/08 06:53:42 | WARNING: Please consider reporting this to the maintainers of com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl
INFO | jvm 1 | 2019/01/08 06:53:42 | WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
INFO | jvm 1 | 2019/01/08 06:53:42 | WARNING: All illegal access operations will be denied in a future release
INFO | jvm 1 | 2019/01/08 06:53:42 | I [g.ModuleManager ] [11:53:42]: Loading modules....
INFO | jvm 1 | 2019/01/08 06:53:42 | I [o.e.j.s.AbstractConnector ] [11:53:42]: Started ServerConnector@6941d248{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 1 | 2019/01/08 06:53:42 | I [o.e.j.s.AbstractConnector ] [11:53:42]: Started ServerConnector@76c0b059{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO | jvm 1 | 2019/01/08 06:53:43 | I [o.e.j.s.AbstractConnector ] [11:53:43]: Started ServerConnector@1d4b79d4{SSL,[ssl, http/1.1]}{0.0.0.0:8043}
INFO | jvm 1 | 2019/01/08 06:53:43 | I [o.e.j.s.Server ] [11:53:43]: Started @3949ms
INFO | jvm 1 | 2019/01/08 06:53:44 | I [A.Notification ] [11:53:44]: Alert notification system created.
INFO | jvm 1 | 2019/01/08 06:53:45 | I [g.PersistentRecordSecurityLevelConfigService] [11:53:45]: Set up in 3 ms
INFO | jvm 1 | 2019/01/08 06:53:45 | I [g.PersistentRecordIdpAdapterConfigService] [11:53:45]: Set up in 18 ms
INFO | jvm 1 | 2019/01/08 06:53:45 | I [g.PersistentRecordIdpAdapterMetricsService] [11:53:45]: Set up in 3 ms
INFO | jvm 1 | 2019/01/08 06:53:45 | I [t.m.provider ] [11:53:45]: Creating new tag store for provider 'System'.
INFO | jvm 1 | 2019/01/08 06:53:47 | I [g.ModuleManager ] [11:53:47]: Setting up modules
INFO | jvm 1 | 2019/01/08 06:53:47 | I [G.L.A.AlarmNotificationService] [11:53:47]: Remote Alarm Notification Manager initialized successfully.
INFO | jvm 1 | 2019/01/08 06:53:47 | I [c.i.i.g.o.KeyStoreManager ] [11:53:47]: Loading KeyStore at /var/lib/ignition/data/opcua/client/security/certificates.pfx
INFO | jvm 1 | 2019/01/08 06:53:48 | I [c.i.i.g.o.KeyStoreManager ] [11:53:47]: Loading KeyStore at /var/lib/ignition/data/opcua/server/security/certificates.pfx
INFO | jvm 1 | 2019/01/08 06:53:48 | I [o.e.m.o.s.s.OpcUaServer ] [11:53:48]: Eclipse Milo OPC UA Stack version: dev
INFO | jvm 1 | 2019/01/08 06:53:48 | I [o.e.m.o.s.s.OpcUaServer ] [11:53:48]: Eclipse Milo OPC UA Server SDK version: dev
INFO | jvm 1 | 2019/01/08 06:53:50 | I [o.e.m.o.s.s.n.OpcUaNamespace ] [11:53:49]: Loaded nodes in 1197ms.
INFO | jvm 1 | 2019/01/08 06:53:50 | I [o.e.m.o.s.s.NamespaceManager ] [11:53:50]: added namespace index=0, uri=http://opcfoundation.org/UA/
INFO | jvm 1 | 2019/01/08 06:53:50 | I [o.e.m.o.s.s.NamespaceManager ] [11:53:50]: registered and added namespace index=1, uri=urn:inductiveautomation:ignition:opcua:server:56004a64-6a44-4605-b066-ffb1b0bee23f
INFO | jvm 1 | 2019/01/08 06:53:50 | I [o.e.m.o.s.s.NamespaceManager ] [11:53:50]: added namespace index=1, uri=urn:inductiveautomation:ignition:opcua:devices
INFO | jvm 1 | 2019/01/08 06:53:50 | I [g.PersistentRecordSecurityLevelConfigService] [11:53:50]: Started up in 0 ms
INFO | jvm 1 | 2019/01/08 06:53:50 | I [g.SecurityLevelManager ] [11:53:50]: Started up in 0 ms
INFO | jvm 1 | 2019/01/08 06:53:50 | I [g.PersistentRecordIdpAdapterConfigService] [11:53:50]: Started up in 0 ms
INFO | jvm 1 | 2019/01/08 06:53:50 | I [g.PersistentRecordIdpAdapterMetricsService] [11:53:50]: Started up in 0 ms
INFO | jvm 1 | 2019/01/08 06:53:50 | I [g.IdpAdapterManager ] [11:53:50]: Started up in 29 ms
INFO | jvm 1 | 2019/01/08 06:53:50 | I [t.provider ] [11:53:50]: Tag provider initialized. Starting to load tags...
INFO | jvm 1 | 2019/01/08 06:53:50 | I [t.provider ] [11:53:50]: Complete tag loading in 122 ms provider=System
INFO | jvm 1 | 2019/01/08 06:53:50 | I [t.manager ] [11:53:50]: Instantiating provider 'default' of type 'STANDARD}'
INFO | jvm 1 | 2019/01/08 06:53:50 | W [p.HistoryManager ] [11:53:50]: Tried to store history while history manager was not running - data will be lost. store-forward-name=Demo, tag=speed
INFO | jvm 1 | 2019/01/08 06:53:51 | I [t.provider ] [11:53:51]: Complete tag loading in 567 ms provider=default
INFO | jvm 1 | 2019/01/08 06:53:51 | I [i.UserSourceManager ] [11:53:51]: Starting up...
INFO | jvm 1 | 2019/01/08 06:53:51 | I [AuditManager ] [11:53:51]: AuditManager starting up...
INFO | jvm 1 | 2019/01/08 06:53:51 | I [A.S.StorageManager ] [11:53:51]: Starting up...
INFO | jvm 1 | 2019/01/08 06:53:51 | I [A.N.NotificationManager ] [11:53:51]: Starting up...
INFO | jvm 1 | 2019/01/08 06:53:51 | I [S.S.HsqlDataStore ] [11:53:51]: Looking for existing store and forward datacache "IGN_auth"... store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose start store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose synched store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache open start store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache open end store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose script done store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache commit start store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache commit end store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose end store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [S.S.HsqlDataStore ] [11:53:52]: ... found existing. store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: Checkpoint start store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: defrag start store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: defrag end store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: Checkpoint end - txts: 103 store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [S.S.HsqlDataStore ] [11:53:52]: store and forward datacache "IGN_auth" started up successfully. store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [S.S.StandardDatasourceSFEngine] [11:53:52]: History sink 'IGN_auth' started successfully. store-forward-name=IGN_auth
INFO | jvm 1 | 2019/01/08 06:53:52 | I [S.S.HsqlDataStore ] [11:53:52]: Looking for existing store and forward datacache "localdb"... store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose start store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose synched store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache open start store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:52 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache open end store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose script done store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache commit start store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:52]: dataFileCache commit end store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:52]: checkpointClose end store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [S.S.HsqlDataStore ] [11:53:52]: ... found existing. store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: Checkpoint start store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: defrag start store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: dataFileCache commit start store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: dataFileCache commit end store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: dataFileCache open start store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: dataFileCache open end store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: defrag end store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [h.d.H.ENGINE ] [11:53:53]: Checkpoint end - txts: 103 store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [S.S.HsqlDataStore ] [11:53:53]: store and forward datacache "localdb" started up successfully. store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [S.S.StandardDatasourceSFEngine] [11:53:53]: History sink 'localdb' started successfully. store-forward-name=localdb
INFO | jvm 1 | 2019/01/08 06:53:53 | I [ImageManager ] [11:53:53]: Starting up...
INFO | jvm 1 | 2019/01/08 06:53:53 | I [ProjectManager ] [11:53:53]: ProjectManager starting up...
INFO | jvm 1 | 2019/01/08 06:53:53 | Fontconfig error: Cannot load default config file
INFO | jvm 1 | 2019/01/08 06:53:53 | E [IgnitionGateway ] [11:53:53]: Error during context startup.
INFO | jvm 1 | 2019/01/08 06:53:53 | java.lang.ExceptionInInitializerError: null
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.lang.Class.getEnumConstantsShared(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.lang.Class.enumConstantDirectory(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.lang.Enum.valueOf(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.EnumHandler.startElement(EnumHandler.java:39)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:866)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:151)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:349)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:259)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:239)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.project.NamedQueryExecutor.lambda$onProjectUpdated$0(NamedQueryExecutor.java:191)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.util.ArrayList.forEach(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.project.NamedQueryExecutor.onProjectUpdated(NamedQueryExecutor.java:187)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.project.NamedQueryExecutor.<init>(NamedQueryExecutor.java:66)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache.<init>(ProjectSettingsCache.java:61)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.project.ProjectManagerImpl.startup(ProjectManagerImpl.java:1781)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:970)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:234)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:650)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:593)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | Caused by: java.lang.ClassCastException: class sun.font.CompositeFont cannot be cast to class sun.font.PhysicalFont (sun.font.CompositeFont and sun.font.PhysicalFont are in module java.desktop of loader 'bootstrap')
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/sun.font.SunFontManager.getDefaultPhysicalFont(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/sun.font.SunFontManager.initialiseDeferredFont(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/sun.font.SunFontManager.findJREDeferredFont(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/sun.font.SunFontManager.findDeferredFont(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/sun.font.SunFontManager.findFont2D(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/java.awt.Font.getFont2D(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/java.awt.Font$FontAccessImpl.getFont2D(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/sun.font.FontUtilities.getFont2D(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/sun.font.FontUtilities.fontSupportsDefaultEncoding(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at java.desktop/javax.swing.text.StyleContext.getFont(Unknown Source)
INFO | jvm 1 | 2019/01/08 06:53:53 | at org.fife.ui.rtextarea.RTextAreaBase.getDefaultFont(RTextAreaBase.java:466)
INFO | jvm 1 | 2019/01/08 06:53:53 | at org.fife.ui.rsyntaxtextarea.Theme.<init>(Theme.java:111)
INFO | jvm 1 | 2019/01/08 06:53:53 | at org.fife.ui.rsyntaxtextarea.Theme.load(Theme.java:341)
INFO | jvm 1 | 2019/01/08 06:53:53 | at org.fife.ui.rsyntaxtextarea.Theme.load(Theme.java:323)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.gui.NamedTheme.<init>(NamedTheme.java:23)
INFO | jvm 1 | 2019/01/08 06:53:53 | at com.inductiveautomation.ignition.common.gui.NamedTheme.<clinit>(NamedTheme.java:14)
INFO | jvm 1 | 2019/01/08 06:53:53 | ... 34 common frames omitted
INFO | jvm 1 | 2019/01/08 06:53:53 | I [IgnitionGateway ] [11:53:53]: Ignition[state=STARTING] ContextState = FAULTED
