[FB12303] Unexpected parsing error during binary deserialization
I have a couple windows from a 7.9.10 project that was imported into 8. There isn’t anything special about these windows (power tables, templates, buttons, script, etc.) that stands out to me from the 20-30 other windows in the project that upgraded fine. Any ideas based on the error below? Or do you need an export? I’m getting this both in the designer and launcher.
12:36:08.509 [AWT-EventQueue-0] ERROR com.inductiveautomation.factorypmi.application.model.WindowCache - Unable to open window "Recipe_Management/Products".
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unexpected parsing error during binary deserialization.
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:358)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:259)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:273)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:216)
	at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:429)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3546)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1327)
	at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.onDoubleClick(WindowNode.java:270)
	at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener$1.run(NavTreePanel.java:678)
Caused by: org.apache.commons.io.IOExceptionWithCause: java.lang.ClassNotFoundException: com.inductiveautomation.vision.api.client.components.model.BaseFormattedTextField$SafeFocusHighlightBorder
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:395)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:356)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readAttributes(BinaryParser.java:179)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:148)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:349)
	... 21 common frames omitted
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.vision.api.client.components.model.BaseFormattedTextField$SafeFocusHighlightBorder
	at java.base/java.net.URLClassLoader.findClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.Class.forName0(Native Method)
	at java.base/java.lang.Class.forName(Unknown Source)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForNameImpl(ClassNameResolver.java:196)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForName(ClassNameResolver.java:169)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:385)
	... 48 common frames omitted
Looks like a bug on our side.
Tracking, this post should get updated when it’s fixed.
This issue was fixed in the build that was uploaded today (2/5). Please let us know if you continue to see this behavior after upgrading.
Still seems to be happening !! I am importing the window from 7.9.10 to 7.8.5. I have done this before but never had this issue !!
Probably a different error since it you aren’t using 8.0, but I’m guessing it isn’t a fan of downgrading versions, and that might be the root cause.
as @grietveld said, this looks like a different error (or cause, anyway) and is likely caused by trying to import a window from a newer version into a older version, which is absolutely unsupported.
Yes, that’s what I was doing ! Had to create the whole screen again !
