[Feature-1023] Change the text style of the title of popups
Ignition 8.1.x
It will be cool if we can have a parameter to change the text style of the title of popups.
system.perspective.openPopup - Ignition User Manual 8.1 - Ignition Documentation (inductiveautomation.com)
We have an open feature to introduce a re-vamp of Popups which would allow for better user customization.
Until then, you can actually do this now as long as you don’t need your Popup to be draggable.
I use a Popup template which accepts a title and a viewPath to construct a Popup. The template View is a Flex Container in column mode with the following layout:
root
L_ FlexContainer (row)
    L_ Label
    L_ Icon (path="material/close")
L_ Embedded View
This template expects params of title, popup_id, and viewPath. The Label text is obviously bound to title, the Icon has an onClick Event which closes a popup with the supplied popup_id, and the Embedded View has its path bound to the incoming viewPath param. You could add a labelStyle param to style your label however you’d like.
Using this template, I open my Popup by supplying the params and specifying that I do NOT want the action to handle the title, draggable, or showCloseIcon settings by setting those all to false.
