[Feature-13764] [perspective] add nullFormat options to table column properties
If a table returns null data from let’s say an outer join query it would be nice to format the null like in the reporting module.
table.props.column.nullFormat or even a table.props.nullFormat to apply across all columns.
The main reason for this request is when we defined column properties the table starts to show null in the table cells. If no columns are defined the cells are blank which is good.
Hi @BumbleBeeTuna,
I’ve put in a ticket to see about the possibility of getting this feature added in the future. I will let you know when I find out more.
Did this feature ever make it into Perspective? I’d also like to prevent null being written to every cell.
Any update on this? Finding almost every table, I need to reformat null values…
