I have a script which is throwing an Error_ScriptEval warning in the script transform editor, but the tooltip provides only part of a stacktrace which refers to internals instead of my code, so I only know where the error is occurring, but not why.
Offending code:
query = 'a working query'
database = 'CRS'
txid = system.db.beginTransaction(database=database, isolationLevel=system.db.SERIALIZABLE, timeout=3000)
system.db.runQuery(query=query, database=database, tx=txid)
Tooltip (line 10 is the system.db.runQuery call):
Error_ScriptEval("Traceback(most recent call last):
File "<transform>", line 10, in transform
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:333)
at jdk,internal.reflect.GeneratedMethodAcccessor226.invoke(Unknown Source)
If I actually trigger the offending code, then logging I’ve place immediately after the offending code is never displayed in the logs. I see no logging of the transform failing, it just quietly fails and doesn’t clarify why.
Any insight would be appreciated!
