I am not able to change the color of the y axis like I can with the time axis. It is stuck at light grey.
Using the style property for each axis, you’ll want to target the stroke styles to modify the vertical axis bar.
Thank you for pointing that out. I have to ask though, why is this different than configuring the time axis? It appears that the style–>stroke works for the time axis too but there is a separate color property for it. Can this be removed to avoid confusion?
The color property on the time axis was just put there as a convenience. Some users like to use only the provided properties to adjust the display of the chart (as opposed to specifying style rules). This just provides a simple way to meet both needs. For consistency, we should probably add the color convenience property to the axes configs so that they match.
Hello,
Very new to ignition here. I also can not change the color and font of the y axis. Could you please explain this step by step. I could not figure which style and stroke it is to change.
