The Chart Range Selector needs a zoom reset button similar to the Time Series Chart
We can add that. I will open a feature request.
Can you add some thing similar vision easy chart time range selector which has ability to change start and end dates on range selector.
What I am doing is using start date and end date inputs to focus the Chart Range Selector (I have turned off the pan zoom feature for now) and then I select the range I want to use on the Time Series Chart with the selected range from the Chart Range Selector. It will definitely be easier when the Easy Chart version is done.
Yes I do exactly like you said.
The good thing about the way chart is the selector is very narrow and use less space. I what some how time selector range only use very narrow space to show chart and select on that like easy chart
