[feature-47]Keyboard shortcut to switch between opened windows in designer
Is there is keyboard shortcut to switch between windows/templates that are open in designer, similar to ctrl+PgUp, ctrl+PgDn in Excel to switch between sheets?
Apparently, it works in Scripting section where we can use above shortcuts to switch between opened scripts.
Not a bad idea. Not sure exactly which shortcuts we would use, but it would probably be pretty easy to implement for the majority of workspaces.
ctrl+Tab will be easier one to use for switching windows in designer with one hand being on mouse and other on keyboard.
