[Feature-7587] Perspective piping: styling for different types of pipes
We use Ignition 8.1.24 where Perspective Piping is introduced (see [New Feature: Perspective Piping)]). We find that the Piping Tool is very helpful. However, we have different product flows (e.g. steam, water…) that we would like to visualize in our views in a dynamic way (e.g. appearance, colors, width, line variation…). In the current Piping Tool we need to going through the nested tree and manually adjust these properties. We find this a major drawback because these pipes/product flows have always the same properties. Furthermore, if we decide to change the color of our steam pipes, we need to do this manually in every view. Finally, is is not possible to select a combination of line types (e.g. Mid Arrow and Dashed).
The figure below represents a simplified version of this problem. The figure shows two steam pipes and two water pipes that are not connected to each other. These two types of pipes has the same properties that must be reconfigured each time we want to visualize.
A feature where it is possible to group pipes and link them, according to their respective product flows, to a predefined class would be very helpful to encounter the problem described above.
The figures below represents a simplified version of a possible solution. The figure shows the grouped steam pipes to which a predefined class (pid-steam) is linked. Analogous for the water pipes.
Hi @Willem_Ver_Eecke , I like your idea of giving each Pipe an individual style prop. I even went as far as began implementing it to see if I could think of any obvious hiccups. I'll be writing an feature ticket for this shortly.
Thanks!
Hi, any updates on this?
I didnt find this exactly feature (styling pipes) listed at Ignition Features and Ideas | Inductive Automation
This would be indeed a very nice feature.
Bumping this again, as I'm currently trying to do pipe animation using style classes, as some of my pipes need to flash (gross I know, but they're important to the operator) and I can't do this without using styles... off to look into hacks now.
Edit: Doesn't look like it's possible with hacks either :confused: I can't give elements particular ids or something to identify them in the DOM
This would definitely be helpful. I am working on a new plant/line. My mapping appears to work, as it calls for the style that I created. But it always goes to the fallback color. I’ve been beating my head on this, but I just assume this isn’t possible yet.
