[FEATURE] Add "Copy url path" or similar to Image Management context menu
Every time (admittedly rarely) I need to use an image stored in the image management file system in Perspective, I always have to look up what the url source needs to be to set to it, i.e. the path copied from the Image Management tool needs to be prefixed with /system/images/. It would be useful if there was an option to copy that path from the context menu. Newcomers would likely spend a while trying to work out why their image isn't showing.
Idea for voting:
Guess I should vote for this since I just had this issue, and remembered seeing this post earlier today..
