[FEATURE]Add Update Prompt with Timeout for Vision
As in Perspective, can a "Prompt with timeout" option be added when configuring the update mode for Vision clients when changes are saved?
We have 100 Vision clients running onsite with changes made and needing to be rolled out which aim to reduce load on the gateway, but they're set to prompt... This means all 100 clients will need to be updated manually :frowning: If there was a timeout like in Perspective, we could just wait for it to elapse.
Use update mode none and the pending update client tag and script something yourself?
https://docs.inductiveautomation.com/display/DOC81/Client+Update+Modes#ClientUpdateModes-NotifyVersusPushVersusNone
Ooh, I forgot about that! (It's been a while since I've used vision..)
Awesome, that will work, cheers!
