[FEATURE] Alarm Metrics - Add overall "Status" integer
In the diy version I was using in previous versions, I had a single “Status” integer tag that summarised all alarm states in the folder, e.g.
if({[.]Active Unack}, 1, // Alarms active and unacked
if({[.]Active Ack}, 2, // ALarms active but all ackd
if({[.]Clear Unack}, -1, // Alarms all cleared but unacked
0))) // No alarms active or unackd
I used this in the display bindings for alarm symbols/colour to make them:
  • flash (unacked alarms exist; Status = 1)
  • solid (all alarms acked but still active; Status = 2), and
  • to display it at all (Status > 0)
I also had a tag with the highest priority as an integer (in the Alarm Metrics there’s only a string version) so that I could more easily find the min/max from a list of priority values. E.g. if you want to know the max/min priority for a range of folders.
It’s a handy way to go for sure. One small suggestion but I find case statements to be nicer looking in this instance with less brackets to fuss about if you add more states.
case(true,
	{[.]Active Unack},1,
	{[.]Active Ack}, 2,
	{Clear Unack}, -1,
	0
I'd love to see a Bool hasActiveUnack added as well.
I believe you can use wildcard notation on the priority. From Ignition 8.3 - Runtime Alarm Metrics:
HasActiveUnacked(*)
Ahh.. I'll have to give it a shot.
