[FEATURE/BUG?] Can't double click on find result to open Perspective resource
I'm tempted to call this a bug, since you can double click on find results from anywhere* else and it takes you to the usage place. If you try to do this if found in Perspective resources though (Views), then it doesn't do anything. Please can this be made consistent with other search results?
Idea:
I just quickly tested this and it works for me. Do you see any errors in the designer console when you try to double click the find result?
