[FEATURE] Context menu option to add all columns from data into Table props.columns
Often I will want to add all or most columns from a Table's data into the props.columns array and configure them, however every time I have to add them manually. It would be nice if there was a context option (similar to embedded view params) to add all columns from the data.
In the meantime, you could add a function to your library that you would use in a script transform to populate the columns. When it's populated, remove the binding and you're done.
It's a bit more steps than a built-in functionality, but while waiting for it to be implemented... it can save you some time.
Yeah, that's what I ended up doing and I saved it for future use. I was going to post it but got carried away working :sweat_smile:
Here it is, in case it's useful to anyone:
Just copy the json, paste it to the binding of the props.columns, then remove it. It'll create items in props.columns for each field in the props.data
  "type": "property",
  "enabled": false,
  "config": {
    "path": "this.props.data"
  "transforms": [
      "code": "\td \u003d {\n\t  \"field\": \"\",\n\t  \"visible\": True,\n\t  \"editable\": False,\n\t  \"render\": \"auto\",\n\t  \"justify\": \"auto\",\n\t  \"align\": \"center\",\n\t  \"resizable\": True,\n\t  \"sortable\": True,\n\t  \"sort\": \"none\",\n\t  \"filter\": {\n\t    \"enabled\": False,\n\t    \"visible\": \"on-hover\",\n\t    \"string\": {\n\t      \"condition\": \"\",\n\t      \"value\": \"\"\n\t    },\n\t    \"number\": {\n\t      \"condition\": \"\",\n\t      \"value\": \"\"\n\t    },\n\t    \"boolean\": {\n\t      \"condition\": \"\"\n\t    },\n\t    \"date\": {\n\t      \"condition\": \"\",\n\t      \"value\": \"\"\n\t    }\n\t  },\n\t  \"viewPath\": \"\",\n\t  \"viewParams\": {},\n\t  \"boolean\": \"checkbox\",\n\t  \"number\": \"value\",\n\t  \"progressBar\": {\n\t    \"max\": 100,\n\t    \"min\": 0,\n\t    \"bar\": {\n\t      \"color\": \"\",\n\t      \"style\": {\n\t        \"classes\": \"\"\n\t      }\n\t    },\n\t    \"track\": {\n\t      \"color\": \"\",\n\t      \"style\": {\n\t        \"classes\": \"\"\n\t      }\n\t    },\n\t    \"value\": {\n\t      \"enabled\": True,\n\t      \"format\": \"0,0.##\",\n\t      \"justify\": \"center\",\n\t      \"style\": {\n\t        \"classes\": \"\"\n\t      }\n\t    }\n\t  },\n\t  \"toggleSwitch\": {\n\t    \"color\": {\n\t      \"selected\": \"\",\n\t      \"unselected\": \"\"\n\t    }\n\t  },\n\t  \"nullFormat\": {\n\t    \"includeNullStrings\": False,\n\t    \"strict\": False,\n\t    \"nullFormatValue\": \"\"\n\t  },\n\t  \"numberFormat\": \"0,0.##\",\n\t  \"dateFormat\": \"YYYY-MM-DD HH:mm:ss\",\n\t  \"width\": \"\",\n\t  \"strictWidth\": False,\n\t  \"style\": {\n\t    \"classes\": \"\"\n\t  },\n\t  \"header\": {\n\t    \"title\": \"\",\n\t    \"justify\": \"left\",\n\t    \"align\": \"center\",\n\t    \"style\": {\n\t      \"classes\": \"\"\n\t    }\n\t  },\n\t  \"footer\": {\n\t    \"title\": \"\",\n\t    \"justify\": \"left\",\n\t    \"align\": \"center\",\n\t    \"style\": {\n\t      \"classes\": \"\"\n\t    }\n\t  }\n\t}\n\tc \u003d []\n\timport copy\n\tfor col in value.columnNames:\n\t\tdd \u003d copy.deepcopy(d)\n\t\tdd[\u0027field\u0027] \u003d col\n\t\tc.append(dd)\n\treturn c",
      "type": "script"
This works only on datasets.
Here's a quick modification to also handle arrays of objects (like the default values when you pull out a table):
json:
  "type": "property",
  "config": {
  "transforms": [
      "code": "\timport copy\n\tfrom com.inductiveautomation.ignition.common import BasicDataset\n\td \u003d {\n\t  \"field\": \"\",\n\t  \"visible\": True,\n\t  \"editable\": False,\n\t  \"render\": \"auto\",\n\t  \"justify\": \"auto\",\n\t  \"align\": \"center\",\n\t  \"resizable\": True,\n\t  \"sortable\": True,\n\t  \"sort\": \"none\",\n\t  \"filter\": {\n\t    \"enabled\": False,\n\t    \"visible\": \"on-hover\",\n\t    \"string\": {\n\t      \"condition\": \"\",\n\t      \"value\": \"\"\n\t    },\n\t    \"number\": {\n\t      \"condition\": \"\",\n\t      \"value\": \"\"\n\t    },\n\t    \"boolean\": {\n\t      \"condition\": \"\"\n\t    },\n\t    \"date\": {\n\t      \"condition\": \"\",\n\t      \"value\": \"\"\n\t    }\n\t  },\n\t  \"viewPath\": \"\",\n\t  \"viewParams\": {},\n\t  \"boolean\": \"checkbox\",\n\t  \"number\": \"value\",\n\t  \"progressBar\": {\n\t    \"max\": 100,\n\t    \"min\": 0,\n\t    \"bar\": {\n\t      \"color\": \"\",\n\t      \"style\": {\n\t        \"classes\": \"\"\n\t      }\n\t    },\n\t    \"track\": {\n\t      \"color\": \"\",\n\t      \"style\": {\n\t        \"classes\": \"\"\n\t      }\n\t    },\n\t    \"value\": {\n\t      \"enabled\": True,\n\t      \"format\": \"0,0.##\",\n\t      \"justify\": \"center\",\n\t      \"style\": {\n\t        \"classes\": \"\"\n\t      }\n\t    }\n\t  },\n\t  \"toggleSwitch\": {\n\t    \"color\": {\n\t      \"selected\": \"\",\n\t      \"unselected\": \"\"\n\t    }\n\t  },\n\t  \"nullFormat\": {\n\t    \"includeNullStrings\": False,\n\t    \"strict\": False,\n\t    \"nullFormatValue\": \"\"\n\t  },\n\t  \"numberFormat\": \"0,0.##\",\n\t  \"dateFormat\": \"YYYY-MM-DD HH:mm:ss\",\n\t  \"width\": \"\",\n\t  \"strictWidth\": False,\n\t  \"style\": {\n\t    \"classes\": \"\"\n\t  },\n\t  \"header\": {\n\t    \"title\": \"\",\n\t    \"justify\": \"left\",\n\t    \"align\": \"center\",\n\t    \"style\": {\n\t      \"classes\": \"\"\n\t    }\n\t  },\n\t  \"footer\": {\n\t    \"title\": \"\",\n\t    \"justify\": \"left\",\n\t    \"align\": \"center\",\n\t    \"style\": {\n\t      \"classes\": \"\"\n\t    }\n\t  }\n\t}\n\theaders \u003d value.columnNames if isinstance(value, BasicDataset) else value[0].keys()\n\tc \u003d []\n\tfor col in headers:\n\t\tdd \u003d copy.deepcopy(d)\n\t\tdd[\u0027field\u0027] \u003d col\n\t\tc.append(dd)\n\treturn c",
      "type": "script"
Here's the transform code:
import copy
d = {
	"field": "",
	"visible": True,
	"editable": False,
	"render": "auto",
	"justify": "auto",
	"align": "center",
	"resizable": True,
	"sortable": True,
	"sort": "none",
	"filter": {
		"enabled": False,
		"visible": "on-hover",
		"string": {
			"condition": "",
			"value": ""
		"number": {
			"condition": "",
			"value": ""
		"boolean": {
			"condition": ""
		"date": {
			"condition": "",
			"value": ""
	"viewPath": "",
	"viewParams": {},
	"boolean": "checkbox",
	"number": "value",
	"progressBar": {
		"max": 100,
		"min": 0,
		"bar": {
			"color": "",
			"style": {
				"classes": ""
		"track": {
			"color": "",
			"style": {
				"classes": ""
		"value": {
			"enabled": True,
			"format": "0,0.##",
			"justify": "center",
			"style": {
				"classes": ""
	"toggleSwitch": {
		"color": {
			"selected": "",
			"unselected": ""
	"nullFormat": {
		"includeNullStrings": False,
		"strict": False,
		"nullFormatValue": ""
	"numberFormat": "0,0.##",
	"dateFormat": "YYYY-MM-DD HH:mm:ss",
	"width": "",
	"strictWidth": False,
	"style": {
		"classes": ""
	"header": {
		"title": "",
		"justify": "left",
		"align": "center",
		"style": {
			"classes": ""
	"footer": {
		"title": "",
		"justify": "left",
		"align": "center",
		"style": {
			"classes": ""
headers = value.columnNames if isinstance(value, BasicDataset) else value[0].keys()
c = []
for col in headers:
	dd = copy.deepcopy(d)
	dd['field'] = col
	c.append(dd)
return c
There might be other types to handle ? I don't know.
