[Feature] dataset with an indexed column and search function
Dataset are everywhere in Ignition.It’s very handy but sometimes we need to search a specific value in a column.
A full scan of a large dataset can be time consuming.
That why if we can define that one column is indexed and have a search function script based on that index.
I’m not sure what this would look like. Is this similar to this other post: http://forum.inductiveautomation.com/t/feature-query-ignition-dataset/20348/5 , where you want a SQL-like ability to access the dataset? I’m not sure how an “index” column would otherwise help in looking at a large dataset.
SQL-like would be good, but SQL Query without index is not better than a loop to full-scan all the dataset.
I think about script function like :
  • system.dataset.addIndex(numColumn)
  • system.dataset.find(numColumn,keyValue) => return the row
Have you used the .getColumnAsList() method? With a list, jython’s .index() method will give you the position (row number) of a value in that column. To go faster, load that column into a dictionary’s keys, with the values being the row number. Voilà, an index. The jython code that does these searches is as optimized as can be.
Yes indeed, that do the job. With the need to update the dictionnary each time you add/remove rows in the dataset. A new user type of dataset with these dictionnary update done in the background can be done, but it’s better if it was built-in in Ignition script system… there are lots of function to manipulate dataset, but nothing to seach in a dataset…
That’s why in script we ofen prefer transfert data in dictionnary ou list to manipulate the data…and it add lots of plumbing code…
Well, that's a new dataset anyways, so it'd have to be a new index. I'll see about adding a searchable dataset implementation to my Simulation Aids module.
Phil,
Do you know where the .getColumnAsList() method is documented? I searched the user manual and couldn’t find a reference. Just curious how you discovered this function. Was very useful by the way!
It is a method of the BasicDataset class (Dataset is an Interface). BasicDataset is the root of pretty much all of the dataset classes that you’ll encounter in Vision.
