[FEATURE] Increase usability of the Perspective Power Chart component
Seems like more of a bug than a usability issue, you should create a new topic for this one
I actually just figured out the issue. My datapath was set to the tagpath, instead of the historical tagpath. :man_facepalming:
FactoryTalk View or Wonderware lol?
Wonderware is such a mess :grin:
I'm also having many useability complaints from our customers with the Power cart components.
Or devices typically transmit data at fixed intervals of anywhere from once every 5-seconds to 12-hours, typically in the 5-minute range.
I want a cart of the actual values in the dB but seems the only way to do that is set the pointCount property to -1 which then if you view anything more than a very small time range the graph grinds to a halt.
Is having a basic graph that looks like this possible on a PowerChart?
I'm a little bit confused by what you're asking for. In your text it seems like you're asking for the power chart to be more performant when showing all data recorded for the pens, but in the image, you're showing the opposite, a very small sample of aggregated points over the time period instead of all of the points recorded. The power chart can certainly show an aggregated sample of points, but it does have some flaws, like that it resamples the data points every time the time advances which causes all of the data points to move around :confused:
E.g.
It's been a while since i've looked at it, and not in the later versions. I really hope that it's improved... I know the time axis has been improved, in that the times are now logical* (hopefully) and track along instead of being fixed in place. That was one of its biggest flaws. But I still hope that things are being done about the realtime/historical modes by getting rid of the distinction which i've documented in many posts in this topic..
if you turn on props.interation.panAndZoom.freeRange then this will remove the data preview chart
What I was referring to is say each dot on that graph example is a datapoint in the history db. What I see with the power chart is if we set the pointCount to say 300 the chart "adds" points to the data and the trend takes steps, furthermore if you export the data from the chart you get lots of repeated data with timestamps that do not align with the actual source data.
I'm looking to have the data on the power chart equate to the data that was sent in from our remote devices and have a trend where each "real" datapoint is connected by a line.
The powerchart is basically using "Wide" history queries under the hood. Wide format is utterly incompatible with point count == -1. AKA "as stored". To get the behavior you are after, you must:
  • Do your own queries, which means
  • Use a different chart type (TS Chart perhaps, but performance sucks).
  • Use "as stored" results with "Tall" format, then
  • Post-process the tall result to group by tag path, yielding a dataset per tag with that tag's actual data, then
  • Further process that data to deliver to the chosen chart type.
(Example in my Tag Report Utility on the Exchange.)
Is there functionality for the date range selector in powerchart to follow locale in the way the normal date range selector can so that you cet 24 hour clock selection?
Example of the range selector with locale activated.
I have a customer doing a POC with ignition and the absolutely biggest complains is exactly all the points listed in this topic regarding the power chart, including 12h clock in the time date picker. The charts is of highest priority to them in a SCADA system. Are there any power chart related updates in 8.3?
Yeah I try to avoid demonstrating the power chart if I can, as it certainly isn't a selling point
That time scale... :grimacing:
Another thing: it's very difficult to use the power chart on a mobile device:
  • you can't drag over the plot in any x-trace to see values of pens across the timeline. e.g. show the x-trace tooltip while dragging [you can very poorly work around this by keeping only the latest x-trace added, but it still means that you have to tap precisely on the timeline where you want to see the values, which of course is impossible on a mobile]
    In fact tapping and dragging doesn't show or add an x-trace at all (check those beautiful dates though)
  • datetimes are just a mess, all rendered over the top of each other
  • axes widths are ridiculously wide and take up precious space
  • the preview window is a bit funny, I can drag to create a view window and I can drag it outside of the view of the preview window
Replying to bump this post, everything you describe here is necessary for a trending tool.
Every feature you listed is frequently asked for in complaints I've gotten, and continue to get, from my users.
Citect Process Analyst was a very good trending tool, super useful and friendly :smiley:
Thanks for bumping! Hopefully once 8.3 is out, IA can spend more time on developing this component so that it's a selling point rather than a let's-hide-that-under-the-carpet point (sorry guys/gals, but ya know it's only been 4 years... user-friendly trend tool, pretty important for a SCADA system...) :grimacing:
Hi, I have posted one issue regarding power chart can you guys please take a look and give your suggestion to fix the issue
I already replied multiple times but i should have suggested that it seemed like a bug
+1 to all points listed in this thread. We are demoing a new SCADA system internally. My initial encounter with Ignition has been great (wonderful documentation & resources , great forum, installation was easy, tag and UDT structure is good, indirect tag binding to make visualization reusable). So it’s quite disappointing to see power chart (and to a lesser extent, sparkline) quite lacking in functionality and usability.
Changes are coming! But they’ll likely take a little while to implement, since the tool is being written using a different base charting library I was told.
