[FEATURE] Make dropdown options an embedded view
Hi there, I have a feature request for the Perspective Dropdown component. I’m trying to build something like this
but with a modern UI design (basically a dropdown with a color picker). I’ve run into situations where a dropdown is the perfect component but the fact that it has very few properties to customize makes it less usable.
Maybe by default it’ll be a simple dropdown where the options object would be a value and a label, but then for a more complicated (useful) dropdown, there could be a property to specify a view.
Interesting idea. I could see lots of scenarios where this might be useful.
In the interim, you could do this with a pseudo “dropdown” done with a flex repeater, and a message handler between the embedded views on-click and the parent view to manage selection.
I was going to use a Table with an column rendered as a view but I think I can get away with using a Flex Repeater like you’re saying. Thanks for the suggestion!
+1 for this request.
I believe IA uses react-select.com for the perspective dropdown and reading their documentation (replacing-components) it seems like it would support using an embedded view
Having a lot of these futures would be amazing. Particularly groups, individual item styling, with per item icons :drooling_face:
It’s probably worth adding to the suggestion box
If only creating perspective components in modules was easier! lol
Speaking of…
It’s honestly not too hard from the little bit I’ve played with it.
I just don’t feel like devoting the time to doing it. Especially for work cause I’m the one who would have to maintain it :frowning:
Upvoted the ideas post :slight_smile:
