[FEATURE] Make Location popup bindable
I want a popup to open at the place that I click with the mouse.
I know there are workarounds but this should be really helpfull.
So it should be nice when the location of the popup is bindable.
Also a open at mouseclick location button should be very helpfull.
Some here might disagree, but I consider the explicit Actions (Popup, Dock, Navigate) to be the alternative, where as invoking those actions from a Script is what I recommend as a primary avenue. Invoking your Popup from a Script Action allows you to set each value visible in this screen through arguments, so you just need to supply the location of the mouse click (obtained from the event argument of the script).
https://docs.inductiveautomation.com/display/DOC80/system.perspective.openPopup
