[FEATURE] position:sticky
Currently you can only sure position:absolute and relative. But there are more usefull ones too like sticky! Currently its only possible to use that in a canvas (i think):
sticky can do this! stick the header and left column to the side depending on scroll direction, cool to make tables or something.
uh a cooler example here (in html+css):
I didn’t have any issues when declaring a sticky position in the designer? I attached a sample video
you arent using canvas? can i see how you did it? when i tried to put sticky, igintion didnt recoginzed it and turned it in their default value (absolute)
I used flexbox. The headers didn’t always stick in the designers preview mode for some reason but it works fine in firefox and chrome.
Sticky is tricky to use at times – Make sure the parent container overflow isn’t set to auto, hidden, or or ANYTHING other than visible.
  "custom": {},
  "params": {},
  "propConfig": {
    "params.feature": {
      "paramDirection": "input"
    "params.key": {
    "params.tier1": {
    "params.tier2": {
  "props": {
    "defaultSize": {
      "height": 4000,
      "width": 1200
  "root": {
    "children": [
        "children": [
            "children": [
                "meta": {
                  "name": "Label"
                "props": {
                  "style": {
                    "color": "white",
                    "fontSize": "48px",
                    "fontWeight": "800",
                    "textAlign": "center"
                  "text": "STICKY HEADER 1"
                "type": "ia.display.label"
            "meta": {
              "name": "sticky-1-header"
            "props": {
              "justify": "center",
              "style": {
                "background-color": "#23cba7",
                "overflow": "visible",
                "position": "sticky  ",
                "top": "70px"
            "type": "ia.container.flex"
        "meta": {
          "name": "header-1-container"
        "position": {
          "shrink": 0
        "props": {
          "direction": "column",
          "style": {
            "background-color": "#F6E5A7",
            "height": "100vh",
        "children": [
            "children": [
                "meta": {
                  "name": "Label"
                "props": {
                  "style": {
                    "color": "white",
                    "fontSize": "48px",
                  "text": "STICKY HEADER 2"
            "meta": {
              "name": "sticky-2-header"
            "props": {
              "style": {
                "top": "70px"
        "meta": {
          "name": "header-2-container"
        "position": {
          "shrink": 0
        "props": {
          "style": {
            "background-color": "#C6E0F6",
            "height": "100vh",
        "children": [
            "children": [
                "meta": {
                  "name": "Label"
                "props": {
                  "style": {
                    "color": "white",
                    "fontSize": "48px",
                  "text": "STICKY HEADER 3"
            "meta": {
              "name": "sticky-3-header"
            "props": {
              "style": {
                "top": "70px"
        "meta": {
          "name": "header-3-container"
        "position": {
          "shrink": 0
        "props": {
          "style": {
            "background-color": "#B8E4CA",
            "height": "100vh",
        "children": [
            "children": [
                "meta": {
                  "name": "Label"
                "props": {
                  "style": {
                    "color": "white",
                    "fontSize": "48px",
                  "text": "STICKY HEADER 4"
            "meta": {
              "name": "sticky-4-header"
            "props": {
              "style": {
                "top": "70px"
        "meta": {
          "name": "header-4-container"
        "position": {
          "shrink": 0
        "props": {
          "style": {
            "background-color": "#F5C094",
            "height": "100vh",
    "meta": {
      "name": "root"
    "props": {
      "style": {
        "paddingTop": "70px"
ah yea like that if you use it on the whole screen, then ignition has an overflow auto on the app-container
else it wouldnt work, for good practice you shouldnt put visible on the root for sure. the root container has to have auto/scroll for sticky to work
.seems that flex containers also work but coordinate ones im pretty sure dont
Hi Eberly,
Thank you for sharing your findings. That's great!
I followed your guide and succeeded in making the target component stick while scrolling.
Key things that I applied are:
  1. User 'Flex' container as the parent (regardless of the view container).
  2. Parent - set 'overflow': 'visible'
  3. Sticky child - set 'position': 'stickly'
  4. Sticky child - set 'top': '0px' (this is the important bit making things work for me)
Hope that would help others too!
java_x1zFF3Kdqj
  "custom": {},
  "params": {},
  "props": {},
  "root": {
    "children": [
        "children": [
            "meta": {
              "name": "sticky"
            "position": {
              "basis": "95px"
            "props": {
              "style": {
                "backgroundColor": "lightgreen",
                "top": "0px"
              "text": "Sticky One"
            "meta": {
              "name": "Label_0"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_1"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_2"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_3"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_4"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_5"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_6"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_7"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_8"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_9"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_10"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_11"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
            "meta": {
              "name": "Label_12"
            "position": {
              "basis": "95px"
            "props": {
              "text": "Label"
        "meta": {
          "name": "FlexContainer"
        "position": {
          "height": "300%",
          "width": 100,
          "x": 1
        "props": {
          "style": {
    "meta": {
      "name": "root"
    "type": "ia.container.coord"
