Running 8.1.27, the default name is Edge Historian.
I'm moving tags to the Edge gateway via EAM and some of the tags have history enabled. However, I have to manually change the storage provider when I do this because I am not able to dynamically assign the storage provider (via binding) or change the name of the default storage provider (unless I just can't find the setting).
IMO, the easiest solution would be to allow the name of the Edge Historian storage provider to be changed.
Maybe I can dig into a config file for now?
