[FEATURE]Restarting a tag from remote tag provider
I think we’re on one of the 8.0.3 nightlies, maybe the rc1. We have a scale out architecture. In the office when we only had one gateway we could restart tags. On site we are developing on a gateway that uses a remote tag provider to connect to the tag gateway. If we try to restart a tag from the dev gateway we get a Bad_Unsupported error.
Is that expected? Is it a bug? Or is there a setting somewhere on the gateway for it?
It’s unsupported right now. We would need to add a “tag restart” remote system call to be able to do this. It could happen down the line, but I have no idea when.
So for scale out architecture where does development usually occur? I don’t think you want engineers developing on the tag gateway as it loads up the gateway with quite a bit of extra work. We have had to restart tags quite a bit as we copy and rename them, which seems like a normal development activity.
Maybe it isn’t a big deal, but it takes away a feature we have had to lean on quite a bit since 8.0.
I want to bump this feature as I’m needing it as well for my scale-out architecture. I don’t really want to have to open a Designer to the backend project every time i want to restart tags :confused:
Bump bump
Bump.
It’s silly how you can do everything with tags except “Restartaring” them from a remote gateway.
You can delete them, but you can’t restart them? - Cmon Inductive!
This should have been filed under a bug ticket imo.
Has this feature been added to any recent releases? Is it planned to be added in any future release?
Something I've found is disabling and then enabling a tag restarts it as well and can be done remotely.
I want to also vote for this feature.
Yes, having the same problem now.
Hi! Any update on this? Thanks.
Maybe even a specific error message in the meantime, because I had no idea what the issue was until I happened across this post..
I also woud like to have this feature. Open each designer to restart a tag is waste of time.
