Currently, when editing a UDT instance/definition in the Tag Editor, you need to do an extra click to access the Parameters β either by clicking on the Parameters section or entering edit mode.
Since parameters are often the first thing you want to check or modify. I think it would be much more efficient if the parameters were shown and editable directly at the root level, without needing to expand or navigate further.
