I am currently using the b2019021902 build.
I need to manage custom SVG icons library. I know there is a “material.svg” file inside the path “\data\modules\com.inductiveautomation.perspective\icons”: I like so much this approach and I would like to personalize some icons in a dedicated library.
As a workaround, I created a “myIcons.svg” inside the same folder and it works fine.
Nevertheless, I am wondering if it is possible to have the icons as project resources (i.e. inside the new data/projects path). In this way, I could version also the icons and transfer easily all the project resources form a gateway to another.
What do you think about?
Thank you,
Andrea
