[FEATURE] Using servlet in custom module
Dears,
I would like to try using a servlet inside a custom module.
I am able to add/remove the servlet in the gateway hook of the module, via:
gatewayContext.getWebResourceManager().addServlet({servlet}.PATH, {servlet}.class);
gatewayContext.getWebResourceManager().removeServlet({servlet}.PATH);
I am wondering if I would be able to access, from the servlet, a class object instantiated in the startup of the module gateway hook.
Thank you.
Best regards.
You’ll have to use a static method in your Gateway Hook class to access a static field containing the object of interest. Store the object of interest in the static field during setup or startup.
Thank you, @pturmel. That’s the right approach.
