I have some doubts in the follwing points;
[b]Can I able to get an SMS alert directly from IGNITION like what we are doing in alert configuration ( mail service ) or I have to install some other software only for SMS purpose.Forexample if the connection lost in OPC Server or some motor get stopped indication, This If I can do it directly through this software, please let me know about this.[/b]
And this is regarding the number tags which I can create in a single group. Is there any limitation for this groups because when I was doing a project I created more than sixty parameters in a single group. Then it started showing some errors in the name of UNCERTAIN, BAD DATA. Then its working after I grouped twenty numbers parameters in a single group without showing any error. I know this excess number will never show any error, but what is the limitation of a single group.
[b]And Regarding the communication between and Sibase database and IGNITION. I need to know that the IGNITION will work with only Sql database or it can work with other database forexample Sibase database. Why I am asking this I was trying to communicate with Siemens WinCc V 5.1 version which has Sibase database, I did not get any result for this. Then I upgraded Siemens WinCc V 5.1 to WinCc V 6.0 + SP-2 which has Sql database.[/b]Whether IGNITION can communicate with any database? If it is yes then why I was unable to get it.
I am expecting a favourable reply from you.
