Fetch out of squence error when insert query is run
I am receiving the error below when I run the query shown below. I have disabled polling on the table component which the insert query is updating. Any help would be greatly appreciated.
Error:
  File "<event:actionPerformed>", line 4, in <module>
  File "<custom-function insertDB>", line 111, in insertDB
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.sql.SQLException: ORA-01002: fetch out of sequence
	caused by GatewayException: java.sql.SQLException: ORA-01002: fetch out of sequence
	caused by Exception: java.sql.SQLException: ORA-01002: fetch out of sequence
Ignition v8.1.35 (b2023120517)
Java: Azul Systems, Inc. 17.0.8
Query being ran:
INSERT INTO RMEDGER_ADDER
	(BASE_ALLOY,
	INGOT_SUPPLIER,
	INGOT_THICKNESS_COLD,
	INGOT_WIDTH_COLD,
	LAST_UPDATE,
	LAST_UPDATE_USERNAME,
	THRESHOLD,
	TARGET_CURRENT,
	EDGER_ADDER,
	SPECIAL_CODE,
	OFFSET_01,
	OFFSET_02,
	OFFSET_03,
	OFFSET_04,
	OFFSET_05,
	OFFSET_06,
	OFFSET_07,
	OFFSET_08,
	OFFSET_09,
	OFFSET_10,
	OFFSET_11,
	OFFSET_12,
	OFFSET_13,
	OFFSET_14,
	OFFSET_15,
	OFFSET_16,
	OFFSET_17,
	OFFSET_18,
	OFFSET_19,
	OFFSET_20,
	OFFSET_21,
	OFFSET_22,
	OFFSET_23,
	OFFSET_24,
	OFFSET_25,
	OFFSET_26,
	OFFSET_27,
	OFFSET_28,
	OFFSET_29,
	OFFSET_30,
	OFFSET_31)
VALUES
	(:Alloy,
	:Supplier,
	:Ingot_Thickness,
	:Ingot_Width,
	TO_DATE(:Last_Update_Time, 'YYYY-MM-DD HH24:MI:SS'),
	:Last_Update_User,
	:Threshold,
	:Target_Current,
	:Edger_Adder,
	:Special_Code,
	:Pass1,
	:Pass2,
	:Pass3,
	:Pass4,
	:Pass5,
	:Pass6,
	:Pass7,
	:Pass8,
	:Pass9,
	:Pass10,
	:Pass11,
	:Pass12,
	:Pass13,
	:Pass14,
	:Pass15,
	:Pass16,
	:Pass17,
	:Pass18,
	:Pass19,
	:Pass20,
	:Pass21,
	:Pass22,
	:Pass23,
	:Pass24,
	:Pass25,
	:Pass26,
	:Pass27,
	:Pass28,
	:Pass29,
	:Pass30,
	:Pass31)
I did verify that the query does work in Oracle Developer with no fetch out of sequence error.
I don't see anything obviously wrong with the query, but I haven't used Oracle in ages. The error itself is purely coming from Oracle's JDBC driver, so you will probably need to research it through them.
This topic has some helpful information:
I suspect you need to run this in an explicit transaction.
I tried running in an explicit transaction, but still got an error. Code below is what is ran once confirmation to insert is given.
from datetime import datetime
def currentDateTime():
	return str(datetime.now()).split('.')[0]
try:
	db = "HMORA2"
	#bind values for named query to current values in data entry boxes
	temp1 = self.getComponent('Pass1_15')
	temp2 = self.getComponent('Pass16_31')
	baseAlloy = self.getComponent('Base Alloy')
	specialCode = self.getComponent('Special Code')
	ingotSupplier = self.getComponent('Ingot Supplier')
	ingotWidth = self.getComponent('Ingot Width')
	ingotThickness = self.getComponent('Ingot Thickness')
	edgerAdder = self.getComponent('Edger Adder')
	targetCurrent = self.getComponent('Target Current')
	threshold = self.getComponent('Threshold')
	dtLastUpdate = self.getComponent('Date Last Update')
	lastUpdateUser = self.getComponent('Last Update User')
	table = self.getComponent('Power Table')
	#get loaded templates as list to access template values
	#capture current username of user during update along with the current time
	temp1List = temp1.getLoadedTemplates()
	temp2List = temp2.getLoadedTemplates()
	lastUpdateUser = system.security.getUsername()
	lastUpdateTime = currentDateTime()
	Pass1 = temp1List[0].getComponent('Numeric Text Field').floatValue
	Pass2 = temp1List[1].getComponent('Numeric Text Field').floatValue
	Pass3 = temp1List[2].getComponent('Numeric Text Field').floatValue
	Pass4 = temp1List[3].getComponent('Numeric Text Field').floatValue
	Pass5 = temp1List[4].getComponent('Numeric Text Field').floatValue
	Pass6 = temp1List[5].getComponent('Numeric Text Field').floatValue
	Pass7 = temp1List[6].getComponent('Numeric Text Field').floatValue
	Pass8 = temp1List[7].getComponent('Numeric Text Field').floatValue
	Pass9 = temp1List[8].getComponent('Numeric Text Field').floatValue
	Pass10 = temp1List[9].getComponent('Numeric Text Field').floatValue
	Pass11 = temp1List[10].getComponent('Numeric Text Field').floatValue
	Pass12 = temp1List[11].getComponent('Numeric Text Field').floatValue
	Pass13 = temp1List[12].getComponent('Numeric Text Field').floatValue
	Pass14 = temp1List[13].getComponent('Numeric Text Field').floatValue
	Pass15 = temp1List[14].getComponent('Numeric Text Field').floatValue
	Pass16 = temp2List[0].getComponent('Numeric Text Field').floatValue
	Pass17 = temp2List[1].getComponent('Numeric Text Field').floatValue
	Pass18 = temp2List[2].getComponent('Numeric Text Field').floatValue
	Pass19 = temp2List[3].getComponent('Numeric Text Field').floatValue
	Pass20 = temp2List[4].getComponent('Numeric Text Field').floatValue
	Pass21 = temp2List[5].getComponent('Numeric Text Field').floatValue
	Pass22 = temp2List[6].getComponent('Numeric Text Field').floatValue
	Pass23 = temp2List[7].getComponent('Numeric Text Field').floatValue
	Pass24 = temp2List[8].getComponent('Numeric Text Field').floatValue
	Pass25 = temp2List[9].getComponent('Numeric Text Field').floatValue
	Pass26 = temp2List[10].getComponent('Numeric Text Field').floatValue
	Pass27 = temp2List[11].getComponent('Numeric Text Field').floatValue
	Pass28 = temp2List[12].getComponent('Numeric Text Field').floatValue
	Pass29 = temp2List[13].getComponent('Numeric Text Field').floatValue
	Pass30 = temp2List[14].getComponent('Numeric Text Field').floatValue
	Pass31 = temp2List[15].getComponent('Numeric Text Field').floatValue
	try:
		#update query params
		path = "EdgerAdder/insertEdgerAdder"
		params = {
			"Alloy": str(baseAlloy.selectedStringValue),
			"Supplier": str(ingotSupplier.selectedStringValue),
			"Special_Code": str(specialCode.selectedStringValue),
			"Last_Update_Time": lastUpdateTime,
			"Last_Update_User": str(lastUpdateUser),
			"Threshold": float(threshold.text),
			"Target_Current": float(targetCurrent.text),
			"Edger_Adder": float(edgerAdder.text),
			"Ingot_Thickness": float(ingotThickness.text),
			"Ingot_Width": float(ingotWidth.text),
			"Pass1": Pass1,
			"Pass2": Pass2,
			"Pass3": Pass3,
			"Pass4": Pass4,
			"Pass5": Pass5,
			"Pass6": Pass6,
			"Pass7": Pass7,
			"Pass8": Pass8,
			"Pass9": Pass9,
			"Pass10": Pass10,
			"Pass11": Pass11,
			"Pass12": Pass12,
			"Pass13": Pass13,
			"Pass14": Pass14,
			"Pass15": Pass15,
			"Pass16": Pass16,
			"Pass17": Pass17,
			"Pass18": Pass18,
			"Pass19": Pass19,
			"Pass20": Pass20,
			"Pass21": Pass21,
			"Pass22": Pass22,
			"Pass23": Pass23,
			"Pass24": Pass24,
			"Pass25": Pass25,
			"Pass26": Pass26,
			"Pass27": Pass27,
			"Pass28": Pass28,
			"Pass29": Pass29,
			"Pass30": Pass30,
			"Pass31": Pass31
		try:
			tx = system.db.beginNamedQueryTransaction(db)
			system.db.runNamedQuery(path, params)
			system.db.commitTransaction(tx)
			system.db.closeTransaction(tx)
		except Exception as e:
			self.error("Insert named query failed! {}".format(e), "NAMED QUERY ERROR")
#		system.db.refresh(table, "data")
	self.success("Insert Successful!", "INSERT CONFIRMATION")
	self.error("Insert Unsuccessful! {}".format(e), "INSERT ERROR")
The thing that is so strange to me is that the data is inserted but the error persists.
You aren't providing the transaction ID to the named query.
SQL throws java errors, so you'll need to catch those instead:
from java.lang import Throwable
try:
except Throwable as e:
That's my bad.
Updated code below and error persists.
            try:
				system.db.runNamedQuery(path, params, tx)
I finally resolved this issue.
I had my query type set to "Query" rather than "Update Query"
