File Not Found using system.file.openFile
Got a weird one. When I try to run this script to convert an excel file to dataset, I get this error.
however, if I hardcode that exact path it works just fine.
and if I do this in the script counsel it works as intended
this one has me stumped
def excelToDataSet(fileName, hasHeaders = False, sheetNum = 0, firstRow = None, lastRow = None, firstCol = None, lastCol = None):
	import org.apache.poi.ss.usermodel.WorkbookFactory as WorkbookFactory
	import org.apache.poi.ss.usermodel.DateUtil as DateUtil
	from java.io import FileInputStream
	from java.util import Date
	   Function to create a dataset from an Excel spreadsheet. It will try to automatically detect the boundaries of the data,
	   but helper parameters are available:
	   params:
	   		fileName   - The path to the Excel spreadsheet. (required)
	   		hasHeaders - If true, uses the first row of the spreadsheet as column names.
	   		sheetNum   - select the sheet to process. defaults to the first sheet.
	   		firstRow   - select first row to process.
	   		lastRow    - select last row to process.
	   		firstCol   - select first column to process
	   		lastCol    - select last column toprocess
	fileStream = FileInputStream(fileName)
	wb = WorkbookFactory.create(fileStream)
	sheet = wb.getSheetAt(sheetNum)
	if firstRow is None:
		firstRow = sheet.getFirstRowNum()
	if lastRow is None:
		lastRow = sheet.getLastRowNum()
	data = []
	for i in range(firstRow , lastRow + 1):
		row = sheet.getRow(i)
		print str(i).zfill(3), list(row)
		if i == firstRow:
			if firstCol is None:
				firstCol = row.getFirstCellNum()
			if lastCol is None:
				lastCol  = row.getLastCellNum()
			else:
				# if lastCol is specified add 1 to it.
				lastCol += 1
			if hasHeaders:
				headers = list(row)[firstCol:lastCol]
			else:
				headers = ['Col'+str(i) for i in range(firstCol, lastCol)]
		rowOut = []
		for j in range(firstCol, lastCol):
			if i == firstRow and hasHeaders:
				pass
			else:
				cell = row.getCell(j)
				cellType = cell.getCellType().toString()
				if cellType == 'NUMERIC':
					if DateUtil.isCellDateFormatted(cell):
						value =  cell.dateCellValue
					else:
						value = cell.getNumericCellValue()
						if value == int(value):
							value = int(value)
				elif cellType == 'STRING':
					value = cell.getStringCellValue()
				elif cellType == 'BOOLEAN':
					value = cell.getBooleanCellValue()
				elif cellType == 'BLANK':
					value = None
				elif cellType == 'FORMULA':
					formulatype=str(cell.getCachedFormulaResultType())
					if formulatype == 'NUMERIC':
						else:
								value = int(value)
					elif formulatype == 'STRING':
					elif formulatype == 'BOOLEAN':
					elif formulatype == 'BLANK':
						value = None
				else:
					value = None
				rowOut.append(value)
		if len(rowOut) > 0:
			data.append(rowOut)
	fileStream.close()
	return system.dataset.toDataSet(headers, data)
# Read .xlsx file
path = system.file.openFile("xlxs")
fName = "'"+path+"'"
#fName = 'C:\Users\jplatt\Documents\data1.xlsx'
ds1 = excelToDataSet(fName, True)
event.source.parent.getComponent('Table 1').data = ds1
Is this Vision or Perspective? (Add the tag below your question title.)
Be aware that Perspective scripts run on the gateway whereas the Script Console runs on the Designer client PC so the C: drive will be different in each case (unless they're the same machine).
Your error screengrab says the FileNotFoundException occurred on line 99 but your code screengrab line 99 doesn't reference the filename. Did you edit the code between screengrabs? If so, please correct your post.
Why are you adding single quotes around the path to build the filename? What you get in path is already a string.
code is update
It vision. Makes sense on the script console being on the local. So even though I can navigate to the file in the when I use the system.file.openFile the client might not be able to retrieve it?
Does this work?
fName = path.replace(r'\', '/')
Hmm, the quotes being funky suggest something's off with the escaping.
Maybe just:
fName = path.replace('\\', '/')
this was an issue with the excel file
all in all Paul's idea worked. Issue was the datatypes were not compatible. If I change all the rows/columns to Text then it works. Onto the next issue, this excel file is also an export from Ignition. So ill need to figure out how to format each column on the export script. Any tips are greatly appreciated
try this code to avoid none datatype error
	   params:
	if lastRow is None:
	data = []
		if i == firstRow:
			if lastCol is None:
			else:
				lastCol += 1
			if hasHeaders:
			else:
		rowOut = []
				pass
			else:
				if cell is None:
					value = ''
				else:
						else:
								value = int(value)
						value = None
							else:
									value = int(value)
							value = None
					else:
						value = None
		if len(rowOut) > 0:
			data.append(rowOut)
	fileStream.close()
# Read .xlsx file
path = system.file.openFile("xlsx")
print ds1
