Hello,
I have a gateway Timers to look for the new file in a mapped drive on gateway !!
Here’s how the script looks like -
import time
import threading
import os
import glob
def getFile():
machine = "MDR 1"
machineFolder = "MDR1"
directory = glob.iglob('E:\\' + machineFolder + '\\*.asc')
newFile = max(directory, key =os.path.getctime)
previousFile = str(system.tag.read("File Directory/%s" % (machine)).value)
if str(previousFile) != str(newFile):
file = open(newFile, "r")
data = [line for line in file.readlines()]
file.close()
system.tag.write("File Directory/%s" % (machine), newFile )
return data, machine
else:
print 'File is processed !'
return None, None
data, machine = getFile()
if data :
project.LabTesting.parseAlphaFile(data, machine)
But I am getting the following error on gateway -
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 25, in File "", line 9, in getFile NameError: global name 'glob' is not defined
at org.python.core.Py.NameError(Py.java:260)
at org.python.core.PyFrame.getglobal(PyFrame.java:265)
at org.python.pycode._pyx40016.getFile$1(:23)
at org.python.pycode._pyx40016.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:120)
at org.python.core.PyFunction.__call__(PyFunction.java:307)
at org.python.pycode._pyx40016.f$0(:28)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:603)
at com.inductiveautomation.ignition.common.script.TimerScriptTask.run(TimerScriptTask.java:88)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
Caused by: org.python.core.PyException: Traceback (most recent call last): File "", line 25, in File "", line 9, in getFile NameError: global name 'glob' is not defined
... 17 common frames omitted
I thought, Including the Glob library would be a easy fix but doesn’t seem to work.
