File upload component / excel read
8.1.33
Trying to use File upload component to upload a excel file. Then I am trying to test out excel dataset read (I might when done put the read script inside the file upload component but currently just testing with script console while I figure out how I want to do script functions.)
So I have file upload that is saving file on gateway.
confirmed file is actually on the gateway
then in script console running this code that I found in forum
from org.apache.poi.ss.usermodel import WorkbookFactory as WorkbookFactory, DateUtil as DateUtil, Row, CellType
from java.io import FileInputStream
from java.util import Date
def excelToDataSet(fileName, hasHeaders = False, sheetNum = 0, firstRow = None, lastRow = None, firstCol = None, lastCol = None):
	fileStream = FileInputStream(fileName)
	wb = WorkbookFactory.create(fileStream)
	sheet = wb.getSheetAt(sheetNum)
	if firstRow is None:
		firstRow = sheet.firstRowNum
	if lastRow is None:
		lastRow = sheet.lastRowNum
	data = []
	for i in range(firstRow , lastRow + 1):
		row = sheet.getRow(i)
		if i == firstRow:
			if firstCol is None:
				firstCol = row.firstCellNum
			if lastCol is None:
				lastCol  = row.lastCellNum
			else:
				# if lastCol is specified add 1 to it.
				lastCol += 1
			if hasHeaders:
				headers = list(row)[firstCol:lastCol]
			else:
				headers = ['Col'+str(cNum) for cNum in range(firstCol, lastCol)]
		rowOut = []
		for j in range(firstCol, lastCol):
			if not (i == firstRow and hasHeaders):
				cell = row.getCell(j,Row.MissingCellPolicy.CREATE_NULL_AS_BLANK)
				cellTypes = (cell.cellType,cell.cachedFormulaResultType if cell.cellType == CellType.FORMULA else None)
				if CellType.NUMERIC in cellTypes:
					if DateUtil.isCellDateFormatted(cell):
						value =  cell.dateCellValue
					else:
						value = cell.numericCellValue
						if value == int(value):
							value = int(value)
				elif CellType.STRING in cellTypes:
					value = cell.stringCellValue
				elif CellType.BOOLEAN in cellTypes:
					value = cell.booleanCellValue
				elif CellType.BLANK in cellTypes:
					value = None
				else:
					value = None
				rowOut.append(value)
		if len(rowOut) > 0:
			data.append(rowOut)
	fileStream.close()
	return system.dataset.toDataSet(headers, data)
dataset= excelToDataSet('<U+202A>C:\IgnitionUploads\Loadsheet1.xlsx', hasHeaders = False, sheetNum = 5, firstRow = 3, lastRow = 5, firstCol = 1, lastCol = 4)
But getting this response
Java Traceback:
  File "<input>", line 62, in <module>
  File "<input>", line 6, in excelToDataSet
	at java.base/java.io.FileInputStream.open0(Native Method)
	at java.base/java.io.FileInputStream.open(Unknown Source)
	at java.base/java.io.FileInputStream.<init>(Unknown Source)
	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Unknown Source)
	at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
	at org.python.core.PyReflectedConstructor.constructProxy(PyReflectedConstructor.java:213)
java.io.FileNotFoundException: java.io.FileNotFoundException: ‪C:\IgnitionUploads\Loadsheet1.xlsx (The filename, directory name, or volume label syntax is incorrect)
any ideas why it is failing to get the file?
Do you not see the goofy character you have at the beginning of your file path?
I don't know where that is coming from
In a file upload, don't use a file stream. Just wrap the event's file bytes in a ByteArrayInputStream, and feed that to POI.
Look a few posts further down from where you found my original script.
ok Here is my script in onFileReceived of file upload
def runAction(self, event):
	event.file.copyTo('c:\IgnitionUploads\Loadsheet1.xlsx')
	from java.io import ByteArrayInputStream
	hasHeaders = False
	sheetNum = 0
	firstRow = 3
	lastRow = 5
	firstCol = 1
	lastCol = 3
	fileStream = ByteArrayInputStream(event.file.getBytes())
	if lastRow is None:
	data = []
		if i == firstRow:
			if lastCol is None:
			else:
				lastCol += 1
			if hasHeaders:
			else:
		rowOut = []
					else:
							value = int(value)
					value = None
				else:
					value = None
		if len(rowOut) > 0:
			data.append(rowOut)
	fileStream.close()
	self.view.getChild("root").custom.ds1 = system.dataset.toDataSet(headers, data)
Here is the sheet I am uploading
results in
com.inductiveautomation.ignition.common.script.JythonExecException
  File "<function:runAction>", line 46, in runAction
AttributeError: 'NoneType' object has no attribute 'getCell'
	caused by org.python.core.PyException
Ignition v8.1.33 (b2023101913)
Java: Azul Systems, Inc. 17.0.8
line 46 is
so looks like I am getting None data into row
ok fixed that by changing my references to base 0
||hasHeaders = False|
||sheetNum = 0|
||firstRow = 2|
||lastRow = 4|
||firstCol = 0|
||lastCol = 3|
Hi, I Have one issue. I want read multiple sheets. any solution?
Thanks in Advance.
take the first part of the "runAction" function above up to sheet=wb.getSheetAt(sheetNum)
make the rest of it its own function and call it for each sheet you want to parse data from. You will get a new dataset from each call. so you can either combine them if it is all the same data or figure out where to store the datasets created.
Thank you for the inputs.
I want to Read last sheet number...
Thanks in Advance.
numSheets = wb.getNumberOfSheets()
sheet = wb.getSheetAt(numSheets-1)
Apache POI Workbook docs. I suggest some reading is in order.
